LG Electronics M2452D-PZ 24" IPS LED Multi Functional Monitor 1920x1080 VGA
Quicklinx: 89SQWS00 Mfr#: M2452D-PZ
LG Full HD monitor TV provides various multimedia entertainment such as HD broadcasting, DVDs, Internet, games and photos. Your viewing pleasure is further enhanced with Full HD picture quality.
  • Lifelike color
    As LG IPS features consistency and less changes in color temperature, it offers a color impression identical to that of the original image.
  • Wide viewing angle
    Enjoy lifelike picture quality without any color shift whether you are standing or lying down.
  • Smooth color change
    The M52D provides clear images with smooth color changes. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
  • Picture-in-Picture
    Picture-in-Picture (PIP) indicates the way of displaying multi-screen at the same time. View and enjoy TV in a sub-screen while using your PC.
  • Super energy saving
    LG LED monitor TV displays a bright screen without image loss while using super energy saving mode. Save more energy than conventional LED TVs and get the best picture quality while doing so.
LG M2452D-PZ - LED monitor with TV tuner - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
26 W
Remote control, TV tuner
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
2xHDMI, VGA, component video
Digital TV Tuner
DVB-C, DVB-T
Display Position Adjustments
Tilt
Black lacquer
56.99 cm x 18 cm x 43.58 cm
4.43 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS
Display Type
Energy Class
Class A
39 kWh
Diagonal Size
24"
Built-in Devices
TV tuner
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Clock
AutoBright, HDCP, SRS TruSurround HD, Hotel Mode, USB MP3/JPEG playback, USB DivX playback, SimpLink, Eco Saving
Black lacquer
56.99 cm x 18 cm x 43.58 cm - with stand
4.43 kg
TV Tuner
Digital TV
DVB-C, DVB-T
Conditional Access
Common Interface (CI) slot
TV Tuner Features
Sleep timer, teletext, auto volume leveler
Audio
Speakers - stereo
Output Power / Channel
5 Watt
Input
Remote control
Movement Detection Technology
Infrared
Headphones , Component video / audio (RCA x 5) , 2 x HDMI , USB 2.0 , SCART , SPDIF output (TOSLINK) , VGA , Serial , Audio line-in
Mechanical
Tilt
VESA Mounting Interface
200 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x video cable
26 W
Dimensions & Weight Details
With stand - width: 56.99 cm - depth: 18 cm - height: 43.58 cm - weight: 4.43 kg , Without stand - width: 56.99 cm - depth: 7 cm - height: 42.86 cm - weight: 4.28 kg
Sustainability Information
ENERGY STAR Certified
