LG Electronics M2232D-PZ 22" LED Monitor with TV tuner 1920x1080 VGA Speake
Quicklinx: 8B05WS00 Mfr#: M2232D-PZ
-Screen Size: 21.5"
-Aspect Ratio: 16:9 -Resolution: 1920 x 1080 -Brightness: 250 cd/m2 -Response Time: 5ms -Contrast Ratio: 1000:1 -Inputs: D-Sub, Composite, SCART, HDMI, CI Card, USB -Audio Inputs: RCA, PC Audio in -Speaker Output: 5W 2ch -Picture Modes: Vivid/Standard/Natural/Cinema/Sport/Game/Expert 1/Expert 2 -General Functions: Intelligent Auto/HDCP/Remote Control/EPG/Teletext/CI Slot/Key Lock/Plug & Play DDC2B -Auto/Manual Clock/Sleep Timer/On-Off Time/Auto Off-Auto Sleep -Power Input: 100~240V
-Power Consumption: Normal - 30W, Power Save/Sleep Mode - 1W, Off 0.4W -Product Colour: Glossy Black
-Dimensions (WxDxH): With Stand - 508.6 x 180.9 x 386.5 mm, Without Stand - 508.6 x 62.9 x 314.8mm -Weight: Without Stand - 2.9kg, With Stand - 3.4kg, Boxed Product - 4.7kg -Included Accessories: Power Cord, Remote Controller
  • Full HD
    Full HD resolution brings you magnificent picture quality through outstanding color accuracy, visual contrast and sharpness.
  • Picture-in-Picture
    Picture-in-Picture (PIP) indicates the way of displaying multi-screen at the same time. View and enjoy TV in a sub-screen while using your PC.
  • USB Quick View (DivX supported)
    The function enables the instant playback of video clips inside USB memory devices by simply connecting the USB to the TV.
  • HDMI
    LG Monitor TVs support a HDMI connector for convenient connection with various HD players.
  • Infinite surround sound
    LG HD sound through an advanced surround sound system. More powerful and deep dimensional sound makes for a more realistic experience.
  • Wall mount
    Try mounting your monitor according to your interior situations and take advantage of the space saving effect.
LG M2232D-PZ - LED monitor with TV tuner - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Remote control, TV tuner
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, composite video, component video
Speakers
Integrated
Digital TV Tuner
DVB-C, DVB-T
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Matte black
50.86 cm x 18.1 cm x 38.65 cm
3.4 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC-2B
Display Type
Energy Class
Class B
Diagonal Size
21.5"
Built-in Devices
TV tuner
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
SUPER Energy Saving Technology
Matte black
50.86 cm x 18.1 cm x 38.65 cm - with stand
3.4 kg
TV Tuner
Analogue Video Format
SECAM, PAL
Digital TV
DVB-C, DVB-T
TV Tuner Features
Auto volume leveler
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
Input
Remote control
Headphones , Component video / audio , HDMI , USB , SCART , VGA , Audio line-in , Composite video
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Backlight Life
50,000 hours
Input Voltage
Power Consumption (Typical)
26 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 50.86 cm - depth: 18.1 cm - height: 38.65 cm - weight: 3.4 kg , Without stand - width: 50.86 cm - depth: 6.29 cm - height: 34.48 cm - weight: 2.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
