By supporting Full HD resolution with 1920 x 1080 pixels, the ideal conditions for 16:9, LG game monitor reproduces myriads of images - from the minute movements of insects to thrilling 3D game - in rich colors and elaborate detail.
HDMI (High Definition Multimedia Interface) connector, which is provided for the monitor's connection with various digital entertainment devices, converts the previously complicated connection of AV cables into a single slim cable. With HDMI connector, audio and video signals of Full HD contents are transmitted without requiring any conversion.
Full HD resolution
By supporting Full HD resolution with 1920 x 1080 pixels, the ideal conditions for 16:9, LG game monitor reproduces myriads of images - from the minute movements of insects to thrilling 3D game - in rich colors and elaborate detail. -
Clean, afterimage-free pictures with 2ms response time
Enjoy clean, afterimage free display of dynamic movies and games supported by extremely fast response time of 2/1,000sec. -
Premium design
Your game zone will be perfected by the monitor's glossy body, rounded edges, and eye - catching transparent color bar. -
HDMI connector
- LG W2261VP - LCD monitor - Full HD (1080p) - 22"
- LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 50000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, hard coating
- Gloss piano black
- 52.1 cm x 22 cm x 43.5 cm
- 4.4 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, UL, TUV, SEMKO, DDC/CI
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 160
- Vertical Viewing Angle
- 170
- Screen Coating
- Controls & Adjustments
- Brightness, contrast, gamma correction, phase, clock
- OSD Languages
- English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek
- sRGB colour management, f-ENGINE technology, HDCP, Digital Fine Contrast (DFC), eZ Zooming
- Gloss piano black
- 4.4 kg
- VGA , DVI-D , HDMI
Mechanical
- Tilt
- Power Supply
- Internal
- Power Consumption (Typical)
- 45 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- ENERGY STAR Certified
- Limited warranty - backlight - 3 years - on-site
