Beauty in the palm of your hands. Metal and glass smoothly float together uninterrupted, without an antenna slit. The sleek design of iconic simplicity comes in rich colors. Unparalleled comfort and fit, that you must hold to believe. Get the whole picture! Human eyes can take in a lot, but this camera grabs even more at 135°. Capture a sprawling skyline, a packed stadium concert, or the entire beach, all that your eyes can see plus more with LG G5.
Go extreme! Zoom out ultra wide. Take various photos and videos from a tight close-up to a vast scene by simply pinching the screen. Just pinch to see it all. The photo is the frame. Take both a standard and wide angle photo at the same time. Make your picture pop and stand out against 4 photo-frame background effects: fisheye, B&W, vignette and lens blur. Your uploads will always get the thumbs-up and hearts of your followers!
Sophisticated metal design
Beauty in the palm of your hands. Metal and glass smoothly float together uninterrupted, without an antenna slit. The sleek design of iconic simplicity comes in rich colors. Unparalleled comfort and fit, that you must hold to believe. -
Wide-angle lens
Get the whole picture! Human eyes can take in a lot, but this camera grabs even more at 135°. Capture a sprawling skyline, a packed stadium concert, or the entire beach, all that your eyes can see plus more. -
Magnifying zoom in and out
Go extreme! Zoom out ultra wide. Take various photos and videos from a tight close-up to a vast scene by simply pinching the screen. Just pinch to see it all. -
Pop-out picture
The photo is the frame. Take both a standard and wide angle photo at the same time. Make your picture pop and stand out against 4 photo-frame background effects: fisheye, B&W, vignette and lens blur. Your uploads will always get the thumbs-up and hearts of your followers! -
Daylight mode
A different kind of "sun" screen. When the sun shines bright, so does the screen. The enhanced IPS Quantum display is brighter, more vivid, and clearer even in outdoor day light. -
Always-on display
Save your thumbs. No more hitting the button to check the time, date, or notifications. With the LG G5, the important stuff is already up and on! Just look.
- LG G5 H850 - titan - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- H850
- Display
- LCD display - 2560 x 1440 pixels - 5.3" - 554 ppi - IPS Quantum
- FM radio
- Processor
- Qualcomm Snapdragon 820 2.1 GHz (quad-core) - 64-bit
- Memory
- RAM 4 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 2 TB
- Operating System
- Android 6.0.1 (Marshmallow)
- Main Camera
- 16 Megapixel - wide-angle lens focus: automatic laser auto focus: - laser focus
- Front Camera
- 8 Megapixel
- Service Provider
- Not specified
- SIM Card
- Nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Titan
- 73.9 mm x 8.6 mm x 149.4 mm
- Specific Absorption Rate (SAR)
- 0.596 W/kg (head) , 1.04 W/kg (body) , 1.185 W/kg (head (simultaneous)) , 1.717 W/kg (body (simultaneous)) , 1.49 W/kg
- Product Type
- Smartphone
- H850
- Form Factor
- Touch
- Integrated Components
- FM radio
- 73.9 mm
- 8.6 mm
- 149.4 mm
- Body Colour
- Titan
- Body Material
- Metal
- SAR Value
- 1.49 W/kg, 1.04 W/kg (body), 0.596 W/kg (head), 1.717 W/kg (body) (simultaneous), 1.185 W/kg (head) (simultaneous)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Navigation
- A-GPS
- SIM Card Type
- Nano SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor
- Security Devices
- Additional Features
- DLNA Certified, Android Beam, QuickRemote function, Capture Plus function, Knock Code function, Smart Keyboard, Easy Home mode, Smart Cleaning, MirrorLink support, Voice Notes, LG AirDrive, Smart Settings, modular design
- Clock Speed
- 2.1 GHz
- Processor Core Qty
- Quad-core
- 64-bit Architecture
- RAM
- 4 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 2 TB
Front Camera
- Sensor Resolution
- 8 Megapixel
Main Camera
- Sensor Resolution
- 16 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS) 2.0
- Lens Type
- Wide-angle lens
- Focus Adjustment
- Automatic
- Laser Auto Focus
- Special Effects
- Film Effects Up
- Camera Modes
- Panorama, Fast Motion mode, manual mode, Expert Mode
- Face Detection
- Face detection
- Light Source
- LED light
- Touch & Shoot, Pause & Resume Recording, auto selfie, snap video, voice trigger, popout picture, Multi View recording, auto recording
Display
- LCD display
- Technology
- IPS Quantum
- Diagonal Size
- 5.3"
- Display Resolution
- Display Format
- QHD
- Pixel Density
- 554 ppi
- Colour Depth
- 16.7 million colours
- Connector Type
- Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
- Technology
- Lithium Ion
- Capacity
- 2800 mAh
- Included Accessories
- Power adapter
