LG 22" E40 monitor series boasts mega ratio contrast technology, resulting in an extremely clear and natural picture quality built into the ultra slim and stylish design. Its dual screen feature optimizes the window size to automatically divide the screen to view multiple web pages and run Microsoft Office at once, making it easier than ever before to multitask online. LG's LED monitors incorporate environmentally-friendly features, including power savings and reduction of hazardous materials used in construction which lowers CO2 emissions created from shipping.
- LG E2240S-PN - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Screen Coating
- Anti-glare, hard coating
- 53 cm x 20.2 cm x 41 cm
- 4.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, cUL
- Display Type
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- Photo Effect
- 4.3 kg
- VGA
- Cables Included
- 1 x VGA cable
- Power Supply
- Internal
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
