LG Electronics DM2352D-PZ 23" 1920x1080 8ms VGA HDMI IPS 3D LED Monitor with TV Tuner
Quicklinx: 8B03WS00 Mfr#: DM2352D-PZ
LG DM2352D-PZ - LED monitor with TV tuner - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Stereo speakers, TV tuner
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA, composite video, component video
Digital TV Tuner
DVB-C, DVB-T
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 120/230 V (47 - 63 Hz)
Piano black
54.41 cm x 18.28 cm x 40.62 cm
3.9 kg
TUV, DDC-2B
Display Type
Energy Class
Class B
Diagonal Size
23"
3D Technology
Polarization
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
HDCP, SUPER Energy Saving Technology, CINEMA 3D technology, 2D to 3D conversion
Piano black
54.41 cm x 18.28 cm x 40.62 cm - with stand
3.9 kg
TV Tuner
Digital TV
DVB-C, DVB-T
Conditional Access
Common Interface Plus (CI+) slot
Audio
Speakers - stereo
Output Power / Channel
5 Watt
VGA , 2 x HDMI , Headphones , USB , SCART , Composite video (RCA x 2) , SPDIF output , Audio line-in , Component video (RCA x 3)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
TUV, DDC-2B
Input Voltage
Power Consumption (Typical)
33 Watt
Included Software
TriDef 3D
Dimensions & Weight Details
With stand - width: 54.41 cm - depth: 18.28 cm - height: 40.62 cm - weight: 3.9 kg , Without stand - width: 54.41 cm - depth: 6.29 cm - height: 33.46 cm - weight: 3.4 kg
Limited warranty - 2 years - pick-up and return
