LG Electronics AV Products 58" 4k Ultra HD Smart TV with Freeview 3 x HDMI WebOS
Quicklinx: BWZTWS00 Mfr#: 58UF830V
Ultra HD 4K resolution is four times that of Full HD, resulting in brilliant clarity and vivid details that amaze, even up close. Enjoy a higher standard of definition. Combining the advancements in color packages and light filtering technology, LG delivers additional color. The result is hidden beauty comes alive as you explore color hues and shades you never knew existed. LG's Smart TV webOS platform revolutionizes the way you watch and experience entertainment on your Ultra HD TV. Free from the complexities of advanced technology, you can enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together some of catch-up TV, movies, sport and music services.
  • Ultra HD 4K resolution
  • ColorPrime
  • WebOS
    LG's Smart TV webOS platform revolutionizes the way you watch and experience entertainment on your Ultra HD TV. Free from the complexities of advanced technology, you can enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together some of catch-up TV, movies, sport and music services. Whatever you wish to watch, find, launch, or play, you can do it easily with webOS, the efficient and user-friendly Smart TV designed with you in mind.
  • Ultra HD 4K streaming
    Thanks to LG's intuitive Smart TV webOS platform you can enjoy Ultra HD 4K content from some of the leading service providers. Say hello to advanced technology, today.
  • 4K Upscaler
    The 4K Upscaler converts lower resolution entertainment to near 4K quality using a unique 6-step image processing technology. So whether it's broadcasts, movies, sports or more, you can enjoy it in incredible detail.
  • ULTRA Surround
    Complete your viewing experience with ULTRA Surround. This multi-channel sound effect will immerse you with realistic audio yet from seven virtual channels.
  • Magic Remote Control
    Access a growing world of entertainment on your LG Smart TV with the intuitive Magic Remote using point, scroll, gesture or voice commands.
  • Plug-and-Play
    With mulitple inputs you can simply plug in your HDMI cable or USB and play out your entertainment, games or digital devices through your TV.
LG 58UF830V 58" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
58"
Platform
webOS 2.0
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
1600 Hz Picture Mastering Index
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
Wi-Fi, LAN
HDCP Compatible
LCD Backlight Technology
Edge-lit LED
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Speaker System
2 speakers
Sound Effects
ULTRA Surround
USB
3 ports
Universal remote
Energy Class
Class A+
89 Watt
Power Consumption Stand by
0.3 Watt
129.8 cm x 5.42 cm x 77 cm
22.8 kg
Energy Class
Class A+
89 Watt
Diagonal Class
58"
Platform
webOS 2.0
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
HDCP Compatible
Dimensions
Without stand
129.8 cm
5.42 cm
77 cm
22.8 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Edge-lit LED
4K Upscaling
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
300 x 300 mm
TV Tuner
Conditional Access
Common Interface (CI) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Media Player
USB Port
USB Ports Qty
3
Remote Control
Universal remote
LG Magic Motion Remote Control
Audio System
Surround Mode
Sound Effects
ULTRA Surround
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in DTS decoder, built-in Dolby Digital decoder
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
Connect & Share
Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
DLNA
Connector Type
Composite video / component video input - rear , Audio line-in - rear , 3 x HDMI - side , USB 3.0 - side , 2 x USB 2.0 - side , Digital audio output (optical) - rear , LAN - rear , SCART - rear , Headphones - rear
Power supply
0.3 Watt
Dimensions & Weight Details
Panel without stand - 129.8 cm x 5.42 cm x 77 cm x 22.8 kg , Panel with stand - 129.8 cm x 26.3 cm x 81.5 cm
Width (Shipping)
139.6 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
85.7 cm
Weight (Shipping)
28 kg
