LG's EC9700 Curved OLED ULTRA HD 4KTV merges advanced technologies into one remarkable television. With OLED's Infinite contrast ratio, the brightest whites to the darkest blacks deliver unmatched color realism. With four times the resolution of Full HD 1080p, Ultra HD 4k offers brilliant clarity from every viewing angle. Together, they transform the viewing experience... and every room setting, with a design that's sleekly curved and pencil-thin.
OLED technology
Discover LG's exclusive WRGB OLED, a display that delivers the ultimate entertainment to your home. Enjoy spectacular picture quality with bright, vibrant colors and high-definition imagery. -
Infinite contrast
LG OLED TVs have an infinite contrast ratio, with self-lighting pixel technology that displays the brightest whites to the deepest blacks for a greater sense of realism. Higher contrast is better, and Infinite has been impossible... until now. -
4 Color Pixel
LG's advanced 4 Color Pixel technology adds an unfiltered, white sub-pixel to the traditional red, green and blue, for a brighter picture with a wider range of colors and superior color accuracy. -
4K technology
With four times the resolution of Full HD 1080p, LG Ultra HD 4K TV amazes with its brilliant clarity. -
4K resolution
LG ULTRA HD TVs offer 4 times the resolution of Full HD for an ultra-clear picture, even on large screens. -
Tru-4K Engine Pro
Our best resolution upscaler yet for content so close to native 4K it is nearly impossible to tell the difference. -
HEVC decoder
Next-generation 4K video uses HEVC-format compression, so a built-in HEVC decoder makes this LG ULTRA HD TV ready to deliver 4K content -
Design
Beautiful impressions start early, with a design that's dramatically curved and sleek as a pencil. -
Pencil thin
LG OLED TV opens up a whole new world of style and design with a depth of only 0.24 inches at its thinnest point, the same thickness as a pencil. -
Curved screen
The curve of the screen is desgined so that your eyes are equally distant from all parts of the screen when sitting in front of the TV, providing a natural and immersive viewing experience. -
LG Smart TV
LG Smart TV makes it easy to connect to Netflix, Hulu Plus, YouTube and more. The Magic Remote lets you simply point, click, scroll and even speak your way to exactly what you want, all with more intuitive webOS user interface. -
webOS
LG Smart TV with the webOS platform is quick to learn and fun to use, easily connecting to other devices, organizing all of your entertainment and searching for more via the intuitive webOS user interface . -
Magic remote
Spend less time navigating and more time enjoying your entertainment . -
4K 3D+
4K 3D+ gives you a more detailed and lifelike experience that will blow you away. -
2D to 3D conversion
LG's 2D-to-3D conversion setting turns movies TV shows and more into 3D. -
Dual play
Two-player gaming on one TV without a split screen.
- LG 65EC970V 65" OLED TV - 4K
- Product Type
- Curved OLED TV with camera - Smart TV
- Diagonal Class
- 65"
- 3D
- Yes (3D glasses (6pcs) included)
- Platform
- webOS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- LCD Backlight Technology
- Pixel dimming
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Internet Streaming Services
- LG Cloud
- Picture Enhancements
- Tru ULTRA HD Engine Pro
- USB
- 3 ports
- Included Accessories
- Universal remote
- Voltage
- AC 230V (50/60 Hz)
- Energy Class
- Class B
- Power Consumption (On mode)
- 213 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 311 kWh
- 144.7 cm x 25.7 cm x 88 cm
- 24.6 kg
- Curved Screen
- Product Type
- Curved OLED TV - Smart TV
- Energy Class
- Class B
- 213 W
- 311 kWh
- Diagonal Class
- 65"
- Combined With
- Camera
- 3D
- 3D Features
- CINEMA 3D Technology, 3D Depth Control, Flicker-free 3D
- Platform
- webOS
- TV Tuner Presence
- Extended PVR
- Sensors
- Intelligent sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- HDCP Compatible
- Dimensions
- With stand
- 144.7 cm
- 25.7 cm
- 88 cm
- 24.6 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Pixel dimming
- Time-shift, 2D to 3D Conversion
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 2000 pages
Media Player
- Supported Video Formats
- DivX HD, H.264
- Supported Audio Formats
- MP3, PCM, AC3, AAC, E-AC3, DTS
- Supported Pictures Formats
- JPG, MPO, JPS
- USB Port
- USB Ports Qty
- 3
Remote Control
- Universal remote
- LG Magic Motion Remote Control
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Mobile High-Definition Link (MHL), Smart Share
- LG Cloud
- Application Store
- LG App Store
- DLNA
- Connector Type
- 2 x USB 2.0 - side , HDMI input - side , SCART - rear , Composite video input - rear , Digital audio output (optical) - rear , LAN - rear , Component video input - rear , Audio line-in - rear , USB 3.0 - side , 3 x HDMI input - rear
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Smart energy saving plus
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel with stand - 144.7 cm x 25.7 cm x 88 cm x 24.6 kg , Panel without stand - 144.7 cm x 5.7 cm x 82.7 cm x 23.2 kg
