Enhance your viewing experience when you bring home the LG 55UF770V Smart Ultra HD 4k 55" LED TV. Offering UHD resolution, this TV lets you enjoy all your favourite shows, apps and web content in stunning quality.
High resolution viewing
The 55UF770V boasts 8.3 million pixels and up to four times the resolution of HD, which means you'll soon be enjoy entertainment packed with incredible detail. Thanks to the IPS technology and wide viewing angles, you'll be sure of a clear view no matter where you're sitting in your living room.
Enjoy movies, TV shows and more in near 4k quality with the 4K Upscaler technology. This six-step processing boosts the resolution of lower definition content, so you can enjoy entertainment with even more detail.
This TV combines the powerful Tru Ultra HD processing engine, backlight scanning technology and a high resolution panel so you'll be sure of the best images possible. It's ideal for fast moving pictures, such as sports and action movies, thanks to the reduced blurring.
webOS
The webOS Smart platform at the heart of the UF770V lets you enjoy the best of the internet on your TV. The simple and intuitive interface brings together some of the best services and content, including 4k movies, sport and music services. Designed with you in mind, webOS makes it easy to find anything you want to watch.
With access to services such as 4k Netflix, you can watch a range of films in fantastic UHD.
The 55UF770 also includes LG's Magic Remote. This intuitive remote lets you point, scroll, gesture or use voice commands to find and view programmes on your TV.
Perfectly designed
The Ribbon stand supplied with the 55UF770V LED TV provides this screen with the elegance it deserves, making your TV a thing of beauty.
The 55UF770V boasts two HDMI 2.0 ports, which allow you to connect your Ultra HD 4k devices, including Blu-ray players and set top boxes.
Four times the resolution, four times the detail
Ultra HD 4K resolution is four times that of Full HD, resulting in brilliant clarity and vivid details that amaze, even up close. Enjoy a new standard of definition. -
Scale new heights of resolution
The 4K Upscaler converts lower resolution entertainment to near 4K quality using a unique 6-step image processing technology. So whether it's broadcasts, movies, sports or more, you can now enjoy it in incredible detail. -
Making TV simple again
LG's Smart TV webOS platform revolutionizes the way you watch and experience entertainment on your UHD TV. Free from the complexities of advanced technology, you can now enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together some of the best catch-up TV, movies, sport and music services. Whatever you wish to watch, find, launch, or play, you can do it easily with webOS, the efficient and user-friendly Smart TV designed with you in mind. -
ULTRA Surround
Complete your viewing experience with ULTRA Surround. This multi-channel sound effect will immerse you with the most realistic audio yet from seven virtual channels. -
Future proof your TV
HDMI 4K can transmit large amounts of data at once. This advanced technology supports 4K video with 60 frames per second, which is the standard for UHD broadcasting. Be ready for the UHD experience for HDMI 4K.
- LG 55UF770V 7 Ultra Series - 55" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 55"
- Platform
- webOS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 24p Technology
- 24p Real Cinema
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight local dimming
- Internet Streaming Services
- Live Menu
- Picture Enhancements
- Dynamic Scanning
- Speaker System
- 2 speakers
- Sound Effects
- SMART SOUND, ULTRA Surround
- Stereo Reception System
- MTS
- USB
- 3 ports
- Included Accessories
- Remote control
- Energy Class
- Class A+
- Power Consumption (On mode)
- 84 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 123 kWh
- Dimensions (WxDxH) - without stand
- 124 cm x 5.67 cm x 72.2 cm
- 17.8 kg
- Product Type
- Energy Class
- Class A+
- 84 W
- 123 kWh
- Diagonal Class
- 55"
- Series
- 7 Ultra Series
- Platform
- webOS
- Operating System
- webOS 2.0
- Video Processor
- Quad-Core
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 3 ports
- HDCP Compatible
- Modes
- Picture mode
- Dynamic Scanning
- Dimensions
- Without stand
- 124 cm
- 5.67 cm
- 72.2 cm
- 17.8 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 24p Technology
- 24p Real Cinema
- Widescreen Modes
- Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
- Time-shift, Micro Pixel Control, Dynamic Color Enhancer, Tru-Ultra HD Engine, TruBlack Control, Dynamic Clear White, Motion eye care, Ultra Luminance, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 300 mm
TV Tuner
- Conditional Access
- Common Interface (CI) slot
- MTS
- Secondary Audio Programme (SAP)
Digital TV Tuner
- HDTV Tuner
Media Player
- Supported Video Formats
- HEVC
- Supported Audio Formats
- MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS
- Supported Pictures Formats
- JPG, MPO, JPS
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
Audio System
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, built-in Dolby Digital decoder, Clear Voice II technology, Sound Optimizer, Wireless Sound Sync, Private Sound Sync, apt-X Encoder
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
- Live Menu
- Application Store
- LG App Store
- Connector Type
- USB 3.0 , 2 x USB 2.0 , 3 x HDMI input , Composite video input , Component video input , Audio line-in , SCART , Digital audio output (optical) , LAN , Headphones , Serial
- Power Device
- Power supply
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 1330 cm x 5.67 cm x 72.2 cm x 17.8 kg , Panel with stand - 1330 cm x 26.1 cm x 77.8 cm x 19.7 kg
- Width (Shipping)
- 133 cm
- Depth (Shipping)
- 15.2 cm
- Height (Shipping)
- 81 cm
- Weight (Shipping)
- 23.8 kg
