LG Electronics 55" 55UH750V 4K UHD Smart TV Web OS
Quicklinx: C5P0WS00 Mfr#: 55UH750V
Hidden beauty comes alive. Combining the innovation in color packages and light filtering technology ColorPrime Pro delivers a wider range of color spectrum. What you are watching is more vibrant and vivid with colors and shades that you never knew existed.
ULTRA Luminance sends excess current from dark areas to brighter areas to enhance contrast. Combine the LG UHD TV's excellent ability to express darkness with its distinct contrast between dark and light, and you have an image that is as sharp and clear as real life.
When something is shown in HDR there is a dynamic range on display that is closer to the huge range of colors and shades that your eye can process. Sun glistens off water, stars shine brighter in the sky - your entertainment comes to life. Content producers are already producing HDR entertainment and LG UHD TV is ready for this content. Open your eyes to the future standard of picture quality.
  • ColorPrime Pro
  • ULTRA Luminance
  • HDR Pro
  • Ultra slim
    Ultra slim, super stylish. An ultra slim construction allows even the biggest screens to have a discreet style. This magnificently modern design is remarkable in any room.
  • LG UHD TV
    A masterpiece for the masses. Perfect harmony between ColorPrime Pro and HDR technologies generates an incredibly rich and vibrant visuals. A stunning picture is complimented by outstanding audio, all housed in a cutting edge construction. This high quality television supports 4K resolution which enables standard definition to upscale to near 4k like quality and is navigated via the award winning Smart TV WebOS.
  • Wide viewing angle
    Due to the nature of the display, the image on the screen maintains its integrity from any viewing angle. This allows you to enjoy dynamic, vibrant color from every seat in the room.
  • 3D color Mapping
    3D color Mapping expresses life like color through its 3D Gamut Mapping algorithm. It minimizes color distortion, allowing viewers to enjoy remarkably natural color.
  • Local Dimming
    Local Dimming adjusts the light by dividing the TV screen into multiple blocks. As the light is controlled independently in each block, details are clearly expressed in each area of the screen. This enables viewers to enjoy deeper blacks and clear, sharp images.
  • Energy saving
    The feature includes backlight control that allows you to adjust the brightness of your screen to conserve energy.
  • Metallic design
    Masterfully manufactured design. A metallic material is wrapped around your television providing a cutting edge construction. This sleek housing adds a modern touch to any living room.
  • ULTRA Surround
    ULTRA Surround sound enables a conventional two-channel speaker to function as a virtual seven-channel speaker. The addition of ULTRA Surround sound technology maximizes the 4K viewing experience.
LG 55UH750V UH750V Series - 55" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
55"
Platform
webOS 3.0
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
HDR Technology
HDR Pro
Frame Rate & Enhancement Technology
1900 Hz Picture Mastering Index
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN, Bluetooth
IPS
LCD Backlight Technology
Edge-lit LED local dimming
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Internet Streaming Services
Smart World
Picture Enhancements
Active Noise Reduction
Speaker System
2 speakers
Sound Effects
ULTRA Surround
USB
3 ports
LG MR15R remote control, batteries
Voltage
Energy Class
Class A+
Power Consumption (On mode)
73 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
107 kWh
123.9 cm x 5.12 cm x 72.6 cm
19.3 kg
Energy Class
Class A+
73 W
107 kWh
Diagonal Class
55"
Series
UH750V Series
Platform
webOS 3.0
HDR Capable
HDR Technology
HDR Pro
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
Design
CINEMA SCREEN design, Ultra Slim Design, Metallic Design
Dimensions
Without stand
123.9 cm
5.12 cm
72.6 cm
19.3 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
Edge-lit LED - local dimming
Time-shift, Eco Flower, Quick Start, E-Manual, Dynamic Color Enhancer, 4K Upscaling, My Channel, Ultra Luminance, True Black, Magic Zoom, UHD Mastering Engine, Color Prime Pro, Magic Mobile Connection, 3D Color Mapping, Channel Advisor
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
300 x 300 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
3
Remote Control
Remote control
Remote Control Model
LG MR15R
Audio System
Digital Audio Format
DTS digital output, DTS-HD digital output
Surround Mode
Sound Effects
ULTRA Surround
Speaker System
2 speakers
Output Power / Total
20 Watt
Smart Sound, Optical Sound Sync, Clear Voice III technology, Magic Sound Tuning
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11ac
Connect & Share
Wi-Fi Direct, Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
Smart World
Supported Consumer Electronics Control (CEC)
Simplink
DLNA
Connector Type
Composite video / component video input , Digital audio output (optical) , 3 x HDMI , LAN , 3 x USB 2.0 , Audio line-out / headphones
Batteries
CEC
Power supply
Input Voltage
0.3 Watt
Dimensions & Weight Details
Panel without stand - 123.9 cm x 5.12 cm x 72.6 cm x 19.3 kg , Panel with stand - 123.9 cm x 21.8 cm x 78.3 cm x 19.7 kg
Width (Shipping)
136 cm
Depth (Shipping)
17.5 cm
Height (Shipping)
83 cm
Weight (Shipping)
24.5 kg
