LG Electronics 50PN650T 50 Inch Plasma TV FHD
Quicklinx: 8NF9WS00 Mfr#: 50PN650T
  • FREEVIEW HD
  • 1080p
With 600 images per second, LG Plasma TV offers clear and smooth images, even during fast motion.
Thanks to its 600Hz sub-field driving technology, the 50PN650T offers the smoothest picture motion. 600Hz technology works by pulsing each frame 12 times, thereby upgrading the standard 50Hz signal to an effective 600Hz one. In essence, this technology gives the 50PN650T a superb response with incredible realism and super-sharp tracking on fast moving motion such as sports events.
Enjoy sheer perfection of color, contrast, and clarity with the all-powerful triple XD engine. LG's advanced triple XD engine brings high level of excellence in color, contrast, and clarity for the best picture quality and performance.
With technologies such as the latest version of LG's highly acclaimed Triple XD Engine, the 50PN650T offers up excellent levels of brightness, colour purity and contrast. The figures showing an astonishing dynamic contrast ratio of 3,000,000:1 are one thing but the proof of this TV's superior picture quality comes in the watching; settle down to watch this TV and the advantages of plasma TV soon become apparent.
Razor Frame
Enjoy immersive viewing and optimal design with razor-thin plasma TV.
Protective Glass
Worried about scratches and damages on your TV screen? LG Plasma TVs are protected by a protective glass, making them the strongest and most durable flat-screen TVs. Reliable tests have been conducted that show just how scratch resistant and sturdy they are. Keep your television in mint condition for as long as you use it.
Using LG's stylish Razor frame, the 50PN650T disguises its size well. The bezel is very slim by plasma standards and, combined with the toughened glass screen, gives a very stylish and sleek appeal. For the ideal viewing angle, the matching stand also has the benefit of swivelling the TV by 20 degrees either way.
  • 600 Hz max
  • Triple XD engine
  • Razor frame
    Enjoy immersive viewing and optimal design with razor-thin Plasma TV.
  • Protective glass
    Worried about scratches and damages on your TV screen? LG Plasma TV is protected by a protective glass, making it the strong and durable flat-screen TV.
LG 50PN650T 50" plasma TV - Full HD
Plasma TV
Diagonal Class
50"
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
720p, 1080i, 1080p
Frame Rate & Enhancement Technology
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
HDCP Compatible
Speaker System
2 speakers
Sound Effects
Virtual Surround Mode
Stereo Reception System
MTS
USB
Remote control
Voltage
Energy Class
Class B
Power Consumption (On mode)
128 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
187 kWh
116.8 cm x 29.27 cm x 75.54 cm
26.1 kg
Plasma TV
Energy Class
Class B
128 W
187 kWh
Diagonal Class
50"
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Design
Razor Frame
Protection
Protection glass
Dimensions
With stand
116.8 cm
29.27 cm
75.54 cm
26.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p
24p Technology
24p Real Cinema
Dynamic Contrast Ratio
3000000:1
Widescreen Modes
Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
3D Noise Reduction, Eye Care, MPEG Noise Reduction, Image Sticking Minimization (ISM), Picture Wizard II, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Features
Swivel
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Conditional Access
Common Interface (CI) slot
MTS
Secondary Audio Programme (SAP)
Digital TV Tuner
HDTV Tuner
Digital TV Service
FREEVIEW HD
Video Features
Input Video Formats
720p, 1080i, 1080p
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
Supported Video Formats
DivX HD
Supported Audio Formats
MP3, WMA, AAC, LPCM, HE-AAC, ADPCM
Supported Pictures Formats
JPG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Digital Audio Format
Dolby Digital output
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
20 Watt
Clear Voice II technology
Speakers
2 x main channel speaker - 10 Watt
Connector Type
Composite video / component video / audio input - rear , Digital audio output (optical) - rear , HDMI input - side , USB 2.0 - side , Audio line-in - rear , HDMI input - rear , SCART - rear
RoHS
Power supply
Input Voltage
0.3 Watt
Dimensions & Weight Details
Panel without stand - 116.8 cm x 5.7 cm x 69.86 cm x 24.7 kg , Panel with stand - 116.8 cm x 29.27 cm x 75.54 cm x 26.1 kg
Width (Shipping)
133 cm
Depth (Shipping)
22.8 cm
Height (Shipping)
81.7 cm
