With 600 images per second, LG Plasma TV offers clear and smooth images, even during fast motion.
Thanks to its 600Hz sub-field driving technology, the 50PN650T offers the smoothest picture motion. 600Hz technology works by pulsing each frame 12 times, thereby upgrading the standard 50Hz signal to an effective 600Hz one. In essence, this technology gives the 50PN650T a superb response with incredible realism and super-sharp tracking on fast moving motion such as sports events.
Enjoy sheer perfection of color, contrast, and clarity with the all-powerful triple XD engine. LG's advanced triple XD engine brings high level of excellence in color, contrast, and clarity for the best picture quality and performance.
With technologies such as the latest version of LG's highly acclaimed Triple XD Engine, the 50PN650T offers up excellent levels of brightness, colour purity and contrast. The figures showing an astonishing dynamic contrast ratio of 3,000,000:1 are one thing but the proof of this TV's superior picture quality comes in the watching; settle down to watch this TV and the advantages of plasma TV soon become apparent.
Razor Frame
Enjoy immersive viewing and optimal design with razor-thin plasma TV.
Protective Glass
Worried about scratches and damages on your TV screen? LG Plasma TVs are protected by a protective glass, making them the strongest and most durable flat-screen TVs. Reliable tests have been conducted that show just how scratch resistant and sturdy they are. Keep your television in mint condition for as long as you use it.
Using LG's stylish Razor frame, the 50PN650T disguises its size well. The bezel is very slim by plasma standards and, combined with the toughened glass screen, gives a very stylish and sleek appeal. For the ideal viewing angle, the matching stand also has the benefit of swivelling the TV by 20 degrees either way.
600 Hz max
With 600 images per second, LG Plasma TV offers clear and smooth images, even during fast motion. -
Triple XD engine
Enjoy sheer perfection of color, contrast, and clarity with the all-powerful triple XD engine. LG's advanced triple XD engine brings high level of excellence in color, contrast, and clarity for the best picture quality and performance. -
Razor frame
Enjoy immersive viewing and optimal design with razor-thin Plasma TV. -
Protective glass
Worried about scratches and damages on your TV screen? LG Plasma TV is protected by a protective glass, making it the strong and durable flat-screen TV.
- LG 50PN650T 50" plasma TV - Full HD
- Product Type
- Plasma TV
- Diagonal Class
- 50"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 720p, 1080i, 1080p
- Frame Rate & Enhancement Technology
- 600Hz sub-field driving
- 24p Technology
- 24p Real Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- Speaker System
- 2 speakers
- Sound Effects
- Virtual Surround Mode
- Stereo Reception System
- MTS
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- Power Consumption (On mode)
- 128 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 187 kWh
- 116.8 cm x 29.27 cm x 75.54 cm
- 26.1 kg
- Product Type
- Plasma TV
- Energy Class
- Class B
- 128 W
- 187 kWh
- Diagonal Class
- 50"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- Design
- Razor Frame
- Protection
- Protection glass
- Dimensions
- With stand
- 116.8 cm
- 29.27 cm
- 75.54 cm
- 26.1 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 24p Technology
- 24p Real Cinema
- Dynamic Contrast Ratio
- 3000000:1
- Widescreen Modes
- Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
- 3D Noise Reduction, Eye Care, MPEG Noise Reduction, Image Sticking Minimization (ISM), Picture Wizard II, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Features
- Swivel
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Conditional Access
- Common Interface (CI) slot
- MTS
- Secondary Audio Programme (SAP)
Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- FREEVIEW HD
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- Supported Video Formats
- DivX HD
- Supported Audio Formats
- MP3, WMA, AAC, LPCM, HE-AAC, ADPCM
- Supported Pictures Formats
- JPG
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Digital Audio Format
- Dolby Digital output
- Surround Mode
- Sound Effects
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Clear Voice II technology
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- Composite video / component video / audio input - rear , Digital audio output (optical) - rear , HDMI input - side , USB 2.0 - side , Audio line-in - rear , HDMI input - rear , SCART - rear
- RoHS
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 116.8 cm x 5.7 cm x 69.86 cm x 24.7 kg , Panel with stand - 116.8 cm x 29.27 cm x 75.54 cm x 26.1 kg
- Width (Shipping)
- 133 cm
- Depth (Shipping)
- 22.8 cm
- Height (Shipping)
- 81.7 cm
