LG Electronics 49UF770V 49" 4K Ultra HD LED Smart TV
Quicklinx: B7PTWS00 Mfr#: 49UF770V
Enhance your viewing experience when you bring home the LG 49UF770V Smart Ultra HD 4k 49" LED TV. Offering UHD resolution, this TV lets you enjoy all your favourite shows, apps and web content in stunning quality.
High resolution viewing
The 49UF770V boasts 8.3 million pixels and up to four times the resolution of HD, which means you'll soon be enjoy entertainment packed with incredible detail. Thanks to the IPS technology and wide viewing angles, you'll be sure of a clear view no matter where you're sitting in your living room.
Enjoy movies, TV shows and more in near 4k quality with the 4K Upscaler technology. This six-step processing boosts the resolution of lower definition content, so you can enjoy entertainment with even more detail.
This TV combines the powerful Tru Ultra HD processing engine, backlight scanning technology and a high resolution panel so you'll be sure of the best images possible. It's ideal for fast moving pictures, such as sports and action movies, thanks to the reduced blurring.
webOS
The webOS Smart platform at the heart of the UF770V lets you enjoy the best of the internet on your TV. The simple and intuitive interface brings together some of the best services and content, including 4k movies, sport and music services. Designed with you in mind, webOS makes it easy to find anything you want to watch.
With access to services such as 4k Netflix, you can watch a range of films in fantastic UHD.
The 49UF770 also includes LG's Magic Remote. This intuitive remote lets you point, scroll, gesture or use voice commands to find and view programmes on your TV.
Perfectly designed
The Ribbon stand supplied with the 49UF770V LED TV provides this screen with the elegance it deserves, making your TV a thing of beauty.
Don't forget your HDMI cables
The 49UF770V boasts two HDMI 2.0 ports, which allow you to connect your Ultra HD 4k devices, including Blu-ray players and set top boxes.
  • Four times the resolution, four times the detail
    ULTRA HD 4K resolution is four times that of Full HD, resulting in brilliant clarity and vivid details that amaze, even up close. Enjoy a new standard of definition.
  • Scale new heights of resolution
    The 4K Upscaler converts lower resolution entertainment to near 4K quality using a unique 6-step image processing technology. So whether it's broadcasts, movies, sports or more, you can now enjoy it in incredible detail.
  • Making TV simple again
    LG's award winning Smart TV webOS platform revolutionizes the way you watch and experience entertainment on your UHD TV. Free from the complexities of advanced technology, you can now enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together some of the best catch-up TV, movies, sport and music services. Whatever you wish to watch, find, launch, or play, you can do it easily with webOS, the efficient and user-friendly Smart TV designed with you in mind.
  • ULTRA Surround
    Complete your viewing experience with ULTRA Surround. This multi-channel sound effect will immerse you with the most realistic audio yet from seven virtual channels.
  • Future proof your TV
    HDMI 4K can transmit large amounts of data at once. This advanced technology supports 4K video with 60 frames per second, which is the standard for UHD broadcasting. Be ready for the UHD experience for HDMI 4K.
  • Bigger screen, bigger experience
    Now you can see more valuable experiences on bigger screen. Select various screen sizes for your various choices.
LG 49UF770V 7 Ultra Series - 49" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
49"
Platform
webOS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight local dimming
Internet Streaming Services
Live Menu
Picture Enhancements
Dynamic Scanning
Speaker System
2 speakers
Sound Effects
SMART SOUND, ULTRA Surround
Stereo Reception System
MTS
USB
3 ports
Remote control
Energy Class
Class A+
Power Consumption (On mode)
67 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
98 kWh
110.4 cm x 5.67 cm x 64.5 cm
14 kg
Energy Class
Class A+
67 W
98 kWh
Diagonal Class
49"
Series
7 Ultra Series
Platform
webOS
Operating System
webOS 2.0
Video Processor
Quad-Core
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
HDCP Compatible
Modes
Picture mode
Dynamic Scanning
Dimensions
Without stand
110.4 cm
5.67 cm
64.5 cm
14 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
24p Technology
24p Real Cinema
Widescreen Modes
Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
Time-shift, Micro Pixel Control, Dynamic Color Enhancer, Tru-Ultra HD Engine, TruBlack Control, Dynamic Clear White, Motion eye care, Ultra Luminance, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
300 x 300 mm
TV Tuner
Conditional Access
Common Interface (CI) slot
MTS
Secondary Audio Programme (SAP)
Digital TV Tuner
HDTV Tuner
Media Player
Supported Video Formats
HEVC
Supported Audio Formats
MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS
Supported Pictures Formats
JPG, MPO, JPS
USB Port
USB Ports Qty
3
Remote Control
Remote control
Audio System
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in DTS decoder, built-in Dolby Digital decoder, Clear Voice II technology, Sound Optimizer, Wireless Sound Sync, Private Sound Sync, apt-X Encoder
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
Connect & Share
Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
Live Menu
Application Store
LG App Store
Connector Type
USB 3.0 , 2 x USB 2.0 , 3 x HDMI input , Composite video input , Component video input , Audio line-in , SCART , Digital audio output (optical) , LAN , Headphones , Serial
Power supply
0.3 Watt
Dimensions & Weight Details
Panel without stand - 110.4 cm x 5.67 cm x 64.5 cm x 14 kg , Panel with stand - 110.4 cm x 26.1 cm x 70.1 cm x 15.9 kg
Width (Shipping)
119.7 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
79 cm
Weight (Shipping)
19.6 kg
