LG Electronics 49UB850V Smart 4K Ultra HD LED 3D Freeview HD TV
Quicklinx: 9P6VWS00 Mfr#: 49UB850V
  • DVB-S
  • DVB-T
ULTRA HD 4K !
LG ULTRA HD 4K TV gives you the best picture quality there is, with four times the detail of Full HD. Our unique IPS Panel allows you to experience perfect clarity, wherever you sit to watch.
Smart TV with webOS
LG Smart TVs with webOS revolutionise the way you watch and experience entertainment on your TV.
Free from the complexities and complications of advanced technology, you can now enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together all your favourite catch-up TV, Movies, Sport and Music services. Whatever you wish to watch, find, launch, or play, you can do it easily with webOS, the efficient and user-friendly Smart TV is designed with you in mind.
2.0 Ch Speaker System
Dual speakers delivering real sound for an incredible cinema-like experience.
CINEMA 3D
Enjoy CINEMA 3D in greater comfort with light, battery-free, and affordable 3D glasses.
Ready for the future
LG ULTRA HD 4K TV delivers the next generation of digital broadcasting with a built in 4K HEVC Decoder that will be the future standard for 4K video compression.
Now you can enjoy 4K quality content via internet streaming or USB without requiring support from any extra device. Enjoy 4K content through external devices with HDMI (4K 60p) compatibility.
Magic Remote
Access a growing world of entertainment on your LG Smart TV with the intuitive Magic Remote using point, scroll, gesture or voice commands.
*Magic Remote included on selected models.
IPS Panel
With LG's unique IPS panel enjoy perfect colour, clarity and contrast, from every seat in the room.
CINEMA Screen
A sleek minimalistic frame that brings cinematic viewing to your home without any obstruction from what you are watching.
  • Ultra HD 4K
    LG Ultra HD 4K TV gives you the best picture quality there is, with four times the detail of Full HD. The unique IPS panel allows you to experience perfect clarity, wherever you sit to watch.
  • Smart TV with webOS
    LG Smart TVs with webOS revolutionize the way you watch and experience entertainment on your TV. Free from the complexities and complications of advanced technology, you can enjoy Smart TV the way it is supposed to be, simple and intuitive, bringing together all your favorite catch-up TV, movies, sport and music services.
  • 2.0 ch speaker system
  • Cinema 3D
    Enjoy Cinema 3D in greater comfort with light, battery-free, and affordable 3D glasses.
  • Ready for the future
    LG Ultra HD 4K TV delivers the next generation of digital broadcasting with a built in 4K HEVC decoder that will be the future standard for 4K video compression. You can enjoy 4K quality content via Internet streaming or USB without requiring support from any extra device. Enjoy 4K content through external devices with HDMI compatibility.
  • IPS panel
    With LG's unique IPS panel enjoy perfect color, clarity and contrast, from every seat in the room.
  • Cinema screen
LG 49UB850V 49" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
49"
3D
Yes (3D glasses (2pcs) included)
3D Technology
Passive
Platform
webOS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
720p, 1080i, 1080p
Frame Rate & Enhancement Technology
1000 Hz Motion Clarity Index
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
Wi-Fi
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight local dimming
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Analogue TV Tuner
PAL, SECAM
Internet Streaming Services
Smart TV Premium, LG Cloud, 3D World, Live Menu
Picture Enhancements
Dynamic Noise Reduction
Speaker System
2 speakers
Sound Effects
SMART SOUND, 3D Sound Zooming
Stereo Reception System
MTS
USB
3 ports
Universal remote
Voltage
Energy Class
Class B
Power Consumption (On mode)
123 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
180 kWh
109.3 cm x 3.82 cm x 64.6 cm
17.5 kg
Energy Class
Class B
123 W
180 kWh
Diagonal Class
49"
3D
3D Technology
Passive - polarised
3D Features
CINEMA 3D Technology, 3D Depth Control, FPR 3D Panel, 3D Viewpoint control, 3D Picture Mode, 3D Format Auto Correction
Platform
webOS
TV Tuner Presence
Sensors
Smart Living sensor
Video Interface
HDMI Ports Qty
4 ports
HDCP Compatible
Modes
Dual Play mode, Picture mode, Smart Picture Mode
Dimensions
Without stand
109.3 cm
3.82 cm
64.6 cm
17.5 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
24p Technology
24p Real Cinema
Widescreen Modes
Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom, Movie Expand 14:9
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Time-shift, 2D to 3D Conversion, Resolution Upscaler, 3D Image Correction, 3D to 2D Conversion, Gesture Control, E-Manual, Dynamic Color Enhancer, TruBlack Control, Tru Color Generator, Dynamic Clear White, Google Dial, Motion eye care, Input Labelling, Picture Wizard II, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface Plus (CI+) slot
MTS
Secondary Audio Programme (SAP)
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
720p, 1080i, 1080p
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
DivX HD, H.264, HEVC
Supported Audio Formats
MP3, PCM, AC3, AAC, HE-AAC, E-AC3, DTS
Supported Pictures Formats
JPG, MPO, JPS
USB Port
USB Ports Qty
3
Remote Control
Universal remote
Smart phone remote support, LG Magic Motion Remote Control, Remote Control App Support
Audio System
Digital Audio Format
Dolby Digital output, DTS digital output
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in DTS decoder, Clear Voice II technology, Voice Control, Audio Return Channel (ARC), Sound Optimizer, apt-X technology, voice search, Optical Sound Sync, Wireless Sound Sync
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing
Wi-Fi
Connect & Share
Wi-Fi Direct, Mobile High-Definition Link (MHL), Intel Wireless Display (WiDi), Wi-Fi Miracast, Smart Share
Supported Consumer Electronics Control (CEC)
Simplink
Application Store
LG App Store
DLNA
Connector Type
Composite video/audio input - rear , Component video input - rear , 4 x HDMI - side , USB 3.0 - side , 2 x USB 2.0 - side , Digital audio output (optical) - rear , Headphones - rear , SCART - rear
Power supply
Input Voltage
0.3 Watt
Dimensions & Weight Details
Panel without stand - 109.3 cm x 3.82 cm x 64.6 cm x 17.5 kg , Panel with stand - 109.3 cm x 23.7 cm x 68.1 cm x 18.5 kg
