LG Electronics 47WL30 47" 1920x1080 9ms DVI-D HDMI DP LED LFD
Quicklinx: 9X7PWS00 Mfr#: 47WL30
  • 1080p
Local Dimming technology allows brightness to be controlled in block units. This ensures brightness and clarity providing high picture quality. As a bonus, power consumption is reduced.
With narrower bezel and slimmer depth than those of competitors, you can save space more efficiently with WL30.
  • Brightness
    It is designed to emit more light which means more luminance and contrast than general screen.
  • Clear and vivid picture
  • Media player integrated solution
    The solution integrated with media player foregoes the need for additional media players and allows you to cut down expenses.
  • Narrow bezel and slim depth
  • Landscape and portrait
    Flexible usage with landscape or portrait display according to the display environment.
LG 47WL30MS WL30MS Series - 47" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080p
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
Speakers not included
USB
Remote control
Voltage
100 Watt
Power Consumption Stand by
0.7 Watt
107.5 cm x 8.45 cm x 62.48 cm
12.3 kg
Environmental Standards
ENERGY STAR Qualified
100 Watt
Diagonal Class
47"
Commercial Use
Series
WL30MS Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
107.5 cm
8.45 cm
62.48 cm
12.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-reflection, 3H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
500000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
9 ms
Image Sticking Minimization (ISM)
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
1080p
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
On/off switch, Clear Voice II technology
Connector Type
HDMI , USB , LAN , DisplayPort input , DVI-D input , DVI-D output , Component video / RGB input , Audio line-in , Serial input , Speakers output , Remote control input
FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.7 Watt
Smart energy saving
Dimensions & Weight Details
Panel without stand - 107.5 cm x 8.45 cm x 62.48 cm x 12.3 kg , Panel with stand - 107.5 cm x 26.39 cm x 69.31 cm x 13.75 kg , Panel with stand and speakers - 107.5 cm x 26.39 cm x 69.31 cm x 14.5 kg
9X7P C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
