LG proprietary touch technology can draw clean and accurate diagonal lines through controlling multi-touch gestures in great precision. It can be used in various high-traffic locations such as subway and exhibition halls for interactive way-finding and informational purposes with improved 10 points touch monitors. LG premium signage display is highly durable, seven days per week for virtually continuous business use.
Gost-free multi-touch experience
LG proprietary touch technology can draw clean and accurate diagonal lines through controlling multi-touch gestures in great precision. -
10 points multi-touch experience
Can be used in various high-traffic locations such as subway and exhibition halls for interactive way-finding and informational purposes with our improved 10 points touch monitors. -
Docking-type professional signage player
Compatible with MP500 player simplifies the cabling and reduces space limitations. -
Greater durability
LG premium signage display is highly durable and designed for operation 24 hours a day, seven days per week for virtually continuous business use.
- LG 47LT55A 47" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 47"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- Speakers not included
- USB
- Included Accessories
- Remote control, IR receiver
- Voltage
- AC 120/230 V (50/60 Hz)
- 125 Watt
- Power Consumption Stand by
- 0.7 Watt
- Dimensions (WxDxH) - without stand
- 110.27 cm x 7.12 cm x 64.78 cm
- 24 kg
- Product Type
- 125 Watt
- Diagonal Class
- 47"
- Commercial Use
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 110.27 cm
- 7.12 cm
- 64.78 cm
- 24 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Anti-glare
- Image Contrast Ratio
- 1300:1
- Dynamic Contrast Ratio
- 500000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 12 ms
- Certified for 24/7 Continuous Operation, Multitouch
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- External Speakers Amplifier Power (Total)
- 20 Watt
- On/off switch, Clear Voice II technology
- Connector Type
- DisplayPort input , Component video / AV / RGB input , HDMI input , USB , Audio line-in , LAN , Serial output , DVI-D input , Serial input , Speakers output , USB 2.0 , Remote control input
- IR receiver
- Cables Included
- VGA cable
- FCC Class A certified, UL, TUV, VCCI, C-Tick, cUL, CB, KCC
- Power Device
- Power supply
- Input Voltage
- 0.7 Watt
- Power Consumption Sleep
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 110.27 cm x 7.12 cm x 64.78 cm x 24 kg
- Width (Shipping)
- 118.7 cm
- Depth (Shipping)
- 14.35 cm
- Height (Shipping)
- 76.5 cm
- Weight (Shipping)
- 27.7 kg
- 0 °C
- 40 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
