LG Ultra HD 4K TV delivers the best picture quality there is, with four times the detail of Full HD. Whether you're watching soaps, sports, movies or more through Smart apps or on Freeview the intuitive 4K Upscaler lets you view it in stunning picture quality.
Uspcaler 4K
Even if the content you're watching isn't in 4K resolution, you can still benefit from the high display quality of LG ULTRA HD TVs. The 4K upscaler developed by LG transforms conventional image quality into extraordinary results. -
4K IPS panel
The secret of LG's superior viewing angle and image quality lies in the panel. LG uses a 4K IPS slab that delivers a clearer, sharper and more stable image. -
Realistic colors
For each of its pixels, the 4K IPS panel renders colors similar to those that make up the original image. Enjoy rich, natural colors across the entire TV screen. -
A wider viewing angle
IPS 4K technology enhances color consistency and contrast from any viewing angle. You benefit from a perfectly calibrated image, wherever you are in the room. -
Multi-channel sound
The TV's multi-channel sound envelops the viewer, being perceived as coming from both top and bottom, left and right, front, back and center.
- LG 43UF640V 43" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Platform
- webOS 2.0
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/60p, 2160/30p, 2160/60p
- 24p Technology
- 24p Real Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED local dimming
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Picture Enhancements
- Tru ULTRA HD Engine Pro
- Speaker System
- 2 speakers
- Stereo Reception System
- MTS
- USB
- Included Accessories
- Remote control
- Energy Class
- Class A
- Power Consumption (On mode)
- 68 W
- Energy Consumption per Year
- 99 kWh
- Dimensions (WxDxH) - without stand
- 97.55 cm x 8.15 cm x 58.24 cm
- Product Type
- Energy Class
- Class A
- 68 W
- 99 kWh
- Diagonal Class
- 43"
- Platform
- webOS 2.0
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- HDCP Compatible
- Dimensions
- Without stand
- 97.55 cm
- 8.15 cm
- 58.24 cm
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 24p Technology
- 24p Real Cinema
- Direct-lit LED - local dimming
- Widescreen Modes
- Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
- Micro Pixel Control, E-Manual, 4K Upscaling, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
- MTS
- Secondary Audio Programme (SAP)
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- HbbTV
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- HEVC
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
- Remote Control App Support
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, built-in Dolby Digital decoder, apt-X technology
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- Connect & Share
- Wi-Fi Direct, Intel Wireless Display (WiDi), Wi-Fi Miracast
- DLNA
- Connector Type
- Composite video / component video input - rear , Audio line-in - rear , SCART - rear , USB 2.0 - side , Digital audio output (optical) - rear , LAN - rear , 2 x HDMI - rear
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 97.55 cm x 8.15 cm x 58.24 cm , Panel with stand - 97.55 cm x 20.87 cm x 62.17 cm
- Width (Shipping)
- 105.6 cm
- Depth (Shipping)
- 15.2 cm
- Height (Shipping)
- 66 cm
