LG Electronics 43UF640V 43" 4K Ultra HD LED Smart TV
Quicklinx: B7PPWS00 Mfr#: 43UF640V
LG Ultra HD 4K TV delivers the best picture quality there is, with four times the detail of Full HD. Whether you're watching soaps, sports, movies or more through Smart apps or on Freeview the intuitive 4K Upscaler lets you view it in stunning picture quality.
  • Uspcaler 4K
    Even if the content you're watching isn't in 4K resolution, you can still benefit from the high display quality of LG ULTRA HD TVs. The 4K upscaler developed by LG transforms conventional image quality into extraordinary results.
  • 4K IPS panel
    The secret of LG's superior viewing angle and image quality lies in the panel. LG uses a 4K IPS slab that delivers a clearer, sharper and more stable image.
  • Realistic colors
    For each of its pixels, the 4K IPS panel renders colors similar to those that make up the original image. Enjoy rich, natural colors across the entire TV screen.
  • A wider viewing angle
    IPS 4K technology enhances color consistency and contrast from any viewing angle. You benefit from a perfectly calibrated image, wherever you are in the room.
  • Multi-channel sound
    The TV's multi-channel sound envelops the viewer, being perceived as coming from both top and bottom, left and right, front, back and center.
LG 43UF640V 43" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
43"
Platform
webOS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Input Video Formats
1080/60p, 2160/30p, 2160/60p
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
Wi-Fi, LAN
HDCP Compatible
LCD Backlight Technology
Direct-lit LED local dimming
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Picture Enhancements
Tru ULTRA HD Engine Pro
Speaker System
2 speakers
Stereo Reception System
MTS
USB
Remote control
Energy Class
Class A
Power Consumption (On mode)
68 W
Energy Consumption per Year
99 kWh
97.55 cm x 8.15 cm x 58.24 cm
Energy Class
Class A
68 W
99 kWh
Diagonal Class
43"
Platform
webOS
Operating System
webOS 2.0
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
HDCP Compatible
Dimensions
Without stand
97.55 cm
8.15 cm
58.24 cm
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
24p Technology
24p Real Cinema
Direct-lit LED - local dimming
Widescreen Modes
Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
Micro Pixel Control, E-Manual, 4K Upscaling, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
MTS
Secondary Audio Programme (SAP)
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
HbbTV
Video Features
Input Video Formats
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
HEVC
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control App Support
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in DTS decoder, built-in Dolby Digital decoder, apt-X technology
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
Wi-Fi, LAN
Connect & Share
Wi-Fi Direct, Intel Wireless Display (WiDi), Wi-Fi Miracast
DLNA
Connector Type
Composite video / component video input - rear , Audio line-in - rear , SCART - rear , USB 2.0 - side , Digital audio output (optical) - rear , LAN - rear , 2 x HDMI - rear
Dimensions & Weight Details
Panel without stand - 97.55 cm x 8.15 cm x 58.24 cm , Panel with stand - 97.55 cm x 20.87 cm x 62.17 cm
Width (Shipping)
105.6 cm
Depth (Shipping)
15.2 cm
Height (Shipping)
66 cm
