Change your settings, in a flash. Picture Wizard allows you to easily adjust picture elements such as black level, color, tint, sharpness and backlight at the touch of a button. Get the right picture for whatever you're watching without the hassle of individual setting adjustment.
Stylish design
Enjoy masterfully manufactured design. The material is wrapped around your television providing excellent construction. This sleek housing adds a modern touch to any living room. -
Virtual Surround
More channels, better sound. High quality construction creates a surround sound effect, producing virtual audio channels. Surround your senses with sound from all angles. -
Clear Voice III
Clear Voice III enhances sound quality by separating voices from background noise to provide you with a clear and crisp listening experience. Focus on your content without distraction using Clear Voice III.
- LG 43LH604V LH604V Series - 43" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 43"
- Platform
- webOS 3.0
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 900 Hz Picture Mastering Index
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Picture Enhancements
- ColourPrime
- Speaker System
- 2 speakers
- Sound Effects
- Virtual Surround Plus
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A++
- Power Consumption (On mode)
- 35 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 51 kWh
- Dimensions (WxDxH) - without stand
- 97.4 cm x 7.94 cm x 57.1 cm
- 9.25 kg
- Product Type
- Energy Class
- Class A++
- 35 W
- 51 kWh
- Diagonal Class
- 43"
- Series
- LH604V Series
- Platform
- webOS 3.0
- TV Tuner Presence
- Extended PVR
- Video Interface
- HDMI Ports Qty
- 3 ports
- ColourPrime
- Dimensions
- Without stand
- 97.4 cm
- 7.94 cm
- 57.1 cm
- 9.25 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Time-shift, Triple XD Engine
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
- Digital TV Service
- HbbTV
- MPEG Profiles and Levels
- MPEG4/MPEG2/HEVC
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Digital Audio Format
- DTS-HD digital output
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Active noise reduction, Clear Voice III technology
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital video playback, WEB browsing
- Connectivity
- Wi-Fi, LAN
- Wi-Fi Protocol
- 802.11n
- DLNA
- Connector Type
- 3 x HDMI , 2 x USB 2.0 , LAN , Composite video / component video input , Headphones , Digital audio output (optical)
- Directive 2009/125/EC, EN 50564:2011, EN 50581:2012, RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2006/95/EC, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN 61000-3-3:2013, EN 55022:2010, EN 55020:2007+A11:2011, EN 55013:2013, EN 62311:2008, EN 61000-3-2:2014, ETSI EN 301 893 V1.7.1, R&TTE Directive 1999/5/EC, IEC 62087-1:2015, EN 300 328 V1.8.1, EN 60065:2014
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 97.4 cm x 7.94 cm x 57.1 cm x 9.25 kg , Panel with stand - 97.4 cm x 19.9 cm x 62 cm x 9.45 kg
- Width (Shipping)
- 106 cm
- Depth (Shipping)
- 15.2 cm
- Height (Shipping)
- 66 cm
- Weight (Shipping)
- 11.7 kg
