LG Electronics 42PN450B 42 Inch Plasma TV
Quicklinx: 8NF8WS00 Mfr#: 42PN450B
  • DVB-T
With 600 images per second, LG 42PN450B Plasma TV offers the clearest and smoothest images, even during fast motion. Enjoy sheer perfection of color, contrast, and clarity with the all-powerful Triple XD Engine. LG's latest and most advanced Triple XD Engine brings the highest level of excellence in color, contrast, and clarity for the best picture quality and performance.
  • 600HZ Max
    With 600 images per second, LG Plasma TV offers the clearest and smoothest images, even during fast motion.
  • Triple XD engine
  • Razor frame
    Enjoy immersive viewing and optimal design with razor-thin plasma TV.
  • Protective glass
    Worried about scratches and damages on your TV screen? LG Plasma TVs are protected by a protective glass, making them the strongest and most durable flat-screen TVs. Reliable tests have been conducted that show just how scratch resistant and sturdy they are. Keep your television in mint condition for as long as you use it.
LG 42PN450B 42" plasma TV - HD
Plasma TV
Diagonal Class
42"
Resolution
1024 x 768
Display Format
720p
Input Video Formats
720p, 1080i, 1080p
Frame Rate & Enhancement Technology
600Hz sub-field driving
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
2 ports
Digital TV Tuner
DVB-C, DVB-T
Speaker System
2 speakers
Sound Effects
Virtual Surround Mode
Stereo Reception System
MTS
USB
Remote control
Energy Class
Class B
Power Consumption (On mode)
93 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
136 kWh
98.36 cm x 25 cm x 65.03 cm
19.6 kg
Plasma TV
Energy Class
Class B
93 W
136 kWh
Diagonal Class
42"
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
Timer Functions
Sleep, wake
Dimensions
With stand
98.36 cm
25 cm
65.03 cm
19.6 kg
Display
Resolution
1024 x 768
Display Format
720p
24p Technology
24p Real Cinema
Dynamic Contrast Ratio
3000000:1
Widescreen Modes
Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
3D Noise Reduction, Eye Care, MPEG Noise Reduction, Picture Wizard II, Triple XD Engine
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Features
Swivel
Flat Panel Mount Interface
400 x 400 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
MTS
Secondary Audio Programme (SAP)
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T
HDTV Tuner
Video Features
Input Video Formats
720p, 1080i, 1080p
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
Supported Video Formats
DivX HD
Supported Audio Formats
MP3, PCM, AC3, AAC, E-AC3, DTS
Supported Pictures Formats
JPG, MPO
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Digital Audio Format
Dolby Digital output, DTS digital output
Surround Mode
Sound Effects
Audio Controls
Sound mode
Speaker System
2 speakers
Output Power / Total
20 Watt
Clear Voice II technology
Speakers
2 x main channel speaker - 10 Watt
Connector Type
Composite video / component video / audio input - rear , Digital audio output (optical) - rear , HDMI input - side , USB 2.0 - side , Audio line-in - rear , HDMI input - rear , SCART - rear
RoHS
Power supply
0.3 Watt
Smart energy saving
Dimensions & Weight Details
Panel without stand - 98.36 cm x 5.7 cm x 59.56 cm x 18.4 kg , Panel with stand - 98.36 cm x 25 cm x 65.03 cm x 19.6 kg
