INCREDIBLE CLARITY, VIBRANT COLOURS
FULL HD 1080p provides the pinnacle of picture resolution with incredible clarity and vibrant colours. With up to five times the resolution compared to standard definition TVs and twice that of `HD-Ready' TVs, FULL HD 1080p is the only way to enjoy the full potential of Blu-ray and HD gaming.
A TVs motion clarity index (MCI) gives you a comprehensive indicator of its ability to handle fast motion without blurring. LG's expertise here makes good use of detailed backlight scanning, advanced local dimming and a powerful clarity engine to deliver a lifelike, detailed picture every time.
High-Definition Multimedia Interface (HDMI) carries both sound and picture in a single cable from your devices to your high definition TV. Now you can easily connect your games console, satellite box, Blu-ray or Home Cinema System through the two HDMI ports for a true high definition entertainment experience
Connect your digital camera, M-P-3 player or USB stick through the USB port to show off your latest holiday snaps, music collection or High Definition movies for a true multimedia experience.
ECO-FRIENDLY REVOLUTION
LG Intelligent Sensor technology automatically finds the optimal brightness, sharpness, colour and contrast picture settings to enhance the picture quality and reduce power consumption.
Smart Energy Saving technology controls the brightness of the TV to reduce the power consumption and therefore help you save money off your electricity bills. The Screen-Off function even lets you listen to music from the TV whilst the screen is off
Incredible clarity, vibrant colors
High definition or HDTV offers greatly improved picture quality and sound than standard definition broadcasts. Finer detail, more colors and more vibrant images make high definition the only choice when upgrading your TV. -
MCI 100
A TVs motion clarity index (MCI) gives you a comprehensive indicator of its ability to handle fast motion without blurring. LG's expertise here makes good use of detailed backlight scanning, advanced local dimming and a powerful clarity engine to deliver a lifelike, detailed picture every time. -
2 x HDMI
High-Definition Multimedia Interface (HDMI) carries both sound and picture in a single cable from your devices to your high definition TV. Now you can easily connect your games console, satellite box, Blu-ray or home cinema system through the two HDMI ports for a true high definition entertainment experience -
USB 2.0
Connect your digital camera, MP3 player or USB stick through the USB port to show off your latest holiday snaps, music collection or high definition movies for a true multimedia experience. -
Eco-friendly revolution
LG Intelligent Sensor technology automatically finds the optimal brightness, sharpness, color and contrast picture settings to enhance the picture quality and reduce power consumption. -
Smart energy saving
Smart Energy Saving technology controls the brightness of the TV to reduce the power consumption and therefore help you save money off your electricity bills. The screen-off function even lets you listen to music from the TV whilst the screen is off.
- LG 42CS460 - 42" LCD TV
- Product Type
- LCD TV
- Display Format
- 1080p (FullHD)
- Diagonal Size
- 42"
- Diagonal Size (cm)
- 107 cm
- Resolution
- 1920 x 1080
- Video Interface
- Component, HDMI, SCART
- HDMI Ports Qty
- 2 port(s)
- HDCP Compatible
- On-screen menu, Intelligent Sensor, Smart Energy Saving Plus, Simplink, Picture Wizard II, Quick View, Triple XD Engine, progressive scan
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Built-in Decoders
- Dolby MS10
- Sound Effects
- Infinite Surround
- Stereo Reception System
- MTS
- USB Port
- Yes , 1 port(s)
- Remote Control
- Remote control
- Power
- AC 120/230 V ( 50/60 Hz )
- Energy Class
- Class C
- 120 Watt
- 102 cm x 26.1 cm x 69.5 cm - with stand
- 15.1 kg
- Product Type
- LCD TV
- Energy Class
- Class C
- 120 Watt
- Diagonal Size
- 42"
- 107 cm
- Video Interface
- HDMI Ports Qty
- 2 port(s)
- HDCP Compatible
- Dimensions
- With stand
- 102 cm
- 26.1 cm
- 69.5 cm
- 15.1 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (FullHD)
- Widescreen Modes
- Zoom 14:9, Conventional 4:3, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
TV Tuner
- Conditional Access
- Common Interface (CI) slot
- MTS
- Secondary Audio Programme (SAP)
Digital TV Tuner
- Digital TV Service
- FREEVIEW
Video Features
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- DivX HD
- Supported Audio Formats
- MP3, PCM, AC3, AAC, E-AC3
- Supported Pictures Formats
- JPG
- USB Port
- Yes , 1 port(s)
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Digital Audio Format
- Dolby Digital output
- Built-in Decoders
- Dolby MS10
- Surround Mode
- Sound Effects
- Infinite Surround
- Audio Controls
- Sound mode
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Clear Voice II technology
- Speaker(s)
- 2 x main channel speaker - built-in - 5 Watt
- Connector Type
- 2 x HDMI input ( 19 pin HDMI Type A ) - rear , 1 x USB 2.0 ( 4 PIN USB Type A ) - side , 1 x component video input ( RCA phono x 3 ) - rear , 1 x audio line-in ( RCA phono x 2 ) - rear , 1 x SCART ( 21 PIN SCART ) - rear
- Expansion Slots
- 1 x Common Interface slot
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Features
- Swivel
- Flat Panel Mount Interface
- 200 x 200 mm
- RoHS
- Power Device
- Power supply - internal
- Nominal Voltage
- Power Consumption Stand by / Sleep
- 0.3 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 102 cm x 26.1 cm x 69.5 cm x 15.1 kg , Panel with stand - 102 cm x 7.7 cm x 62.9 cm x 13.5 kg
