LG Electronics 34UM65-P 34" 2560x1080 5ms DVI HDMI DisplayPort IPS LED Monitor
Quicklinx: 9D5GWS00 Mfr#: 34UM65-P
The 34UM65 satisfies your demands for viewing pleasure and entertainment. Put high spec games on the 21:9 wide screen with astonishing picture quality of UltraWide Full HD (2560x1080) accompanied by 7W stereo speakers and satisfy your desire for the most realistic gaming experience and movie adventures.
  • 21:9 UltraWide Full HD
  • 4-Screen Split
    With a 21:9 wide screen ratio, now you can multitask with 4 programs on one screen at the same time. This 4-Screen Split feature conveniently divides your screen from 2 to 4 customizable subscreens of your preferred size, without any overlapping of windows. Compatible with Mac, it provides 8 different screen ratios, changeable by a single click, and increases not only your convenience but also productivity.
  • Dual Link-up
    The Dual Link-up feature allows two devices to be displayed simultaneously on a single screen. With the monitor, you can connect and watch a movie from a Blu-ray player while working on an Excel spreadsheet from your PC. With the 29UM65's upgraded Dual Link-up, it enables HDMI+HDMI links, now you can connect devices more conveniently.
  • Reader Mode
    Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to.
  • Stereo speaker
    Enjoy your movies or games with realistic stereo sound.With the built in stereo speaker, there is no need for extra speakers around your monitor.
  • IPS display
    As LG IPS monitor features consistency and less changes in color temperature, it offers a color impression identical to that of the original image. You can enjoy lifelike picture picture quality without any color shift whether you are standing or lying down. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
  • Flicker safe
    Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
  • Joystick
    The joystick is a harmony of accurate menu controls and analog sensitivity. With the fun control of a conventional joystick, its modern technology and design allow for simple control with a pleasant touch. In addition, intuitive UI with no overlapping is easier to understand and select menus.
LG 34UM65-P - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
71 kWh
Power Consumption (On mode)
49 W
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080 at 60 Hz
Pixel Pitch
0.315 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
High-gloss piano lacquer black
82.99 cm x 17.3 cm x 46.89 cm
7.7 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, EN55022 Class B, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006
Display Type
Energy Class
Class B
71 kWh
Diagonal Size
34"
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.315 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
sRGB colour management, HDCP, SUPER Energy Saving Technology, Multiscan Support, CINEMA Screen Design, Lifelike Color
82.99 cm x 17.3 cm x 46.89 cm - with stand
7.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
7 Watt
DVI-D (dual link) (HDCP) , 2 x HDMI , Audio line-in , DisplayPort , Audio line-out
Mechanical
Height, tilt
Tilt Angle
-5/+15
Height Adjustment
20 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable , 1 x audio cable , 1 x HDMI cable
Backlight Life
50,000 hours
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
49 W
Power Consumption (Typical)
80 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 82.99 cm - depth: 17.3 cm - height: 46.89 cm - weight: 7.7 kg , Without stand - width: 82.99 cm - depth: 8.29 cm - height: 37.98 cm - weight: 6.7 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
