The 34UM65 satisfies your demands for viewing pleasure and entertainment. Put high spec games on the 21:9 wide screen with astonishing picture quality of UltraWide Full HD (2560x1080) accompanied by 7W stereo speakers and satisfy your desire for the most realistic gaming experience and movie adventures.
21:9 UltraWide Full HD
The 34UM65 satisfies your demands for viewing pleasure and entertainment. Put high spec games on the 21:9 wide screen with astonishing picture quality of UltraWide Full HD (2560x1080) accompanied by 7W stereo speakers and satisfy your desire for the most realistic gaming experience and movie adventures. -
4-Screen Split
With a 21:9 wide screen ratio, now you can multitask with 4 programs on one screen at the same time. This 4-Screen Split feature conveniently divides your screen from 2 to 4 customizable subscreens of your preferred size, without any overlapping of windows. Compatible with Mac, it provides 8 different screen ratios, changeable by a single click, and increases not only your convenience but also productivity. -
Dual Link-up
The Dual Link-up feature allows two devices to be displayed simultaneously on a single screen. With the monitor, you can connect and watch a movie from a Blu-ray player while working on an Excel spreadsheet from your PC. With the 29UM65's upgraded Dual Link-up, it enables HDMI+HDMI links, now you can connect devices more conveniently. -
Reader Mode
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to. -
Stereo speaker
Enjoy your movies or games with realistic stereo sound.With the built in stereo speaker, there is no need for extra speakers around your monitor. -
IPS display
As LG IPS monitor features consistency and less changes in color temperature, it offers a color impression identical to that of the original image. You can enjoy lifelike picture picture quality without any color shift whether you are standing or lying down. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort. -
Flicker safe
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction. -
Joystick
The joystick is a harmony of accurate menu controls and analog sensitivity. With the fun control of a conventional joystick, its modern technology and design allow for simple control with a pleasant touch. In addition, intuitive UI with no overlapping is easier to understand and select menus.
- LG 34UM65-P - LED monitor - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class B
- Energy Consumption per Year
- 71 kWh
- Power Consumption (On mode)
- 49 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080 at 60 Hz
- Pixel Pitch
- 0.315 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Speakers
- Integrated
- Height, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- High-gloss piano lacquer black
- 82.99 cm x 17.3 cm x 46.89 cm
- 7.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, EN55022 Class B, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 71 kWh
- Diagonal Size
- 34"
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.315 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- sRGB colour management, HDCP, SUPER Energy Saving Technology, Multiscan Support, CINEMA Screen Design, Lifelike Color
- 82.99 cm x 17.3 cm x 46.89 cm - with stand
- 7.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 7 Watt
- DVI-D (dual link) (HDCP) , 2 x HDMI , Audio line-in , DisplayPort , Audio line-out
Mechanical
- Height, tilt
- Tilt Angle
- -5/+15
- Height Adjustment
- 20 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable , 1 x audio cable , 1 x HDMI cable
- Backlight Life
- 50,000 hours
- MTBF
- 50,000 hour(s)
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 49 W
- Power Consumption (Typical)
- 80 Watt
- Power Consumption Stand by
- 1.2 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 82.99 cm - depth: 17.3 cm - height: 46.89 cm - weight: 7.7 kg , Without stand - width: 82.99 cm - depth: 8.29 cm - height: 37.98 cm - weight: 6.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - pick-up and return
