LG Electronics 32LN5400 32" Full HD LED TV Full HD 1920 x 1080
Quicklinx: 8Z1RWS00 Mfr#: 32LN5400
  • 1080p
  • DVB-T
  • DVB-S
Incredible Clarity, Vibrant Colours
FULL HD 1080p provides the pinnacle of picture resolution with incredible clarity and vibrant colours. With up to five times the resolution compared to standard definition TVs and twice that of `HD-Ready' TVs, FULL HD 1080p is the only way to enjoy the full potential of Blu-ray and HD gaming.
HDMI
High-Definition Multimedia Interface (HDMI) carries both sound and picture in a single cable from your devices to your high definition TV. Now you can easily connect your games console, satellite box, Blu-ray or Home Cinema System through the HDMI ports for a true high definition entertainment experience
Freeview
Get ready for the digital switch-over.
All LG TVs come with built-in Digital Freeview making sure you're ready for the digital switch-over. With LG TVs you'll have access to over 40 Freeview TV and radio channels, 8 day on-screen guide and access to digital interactive services.
*UK Only
  • Slim and narrow design
    Narrow bezel is a slim frame that reduces visual obstruction for improved TV viewing and with the addition of slim depth panels provides an elegant design for your living room.
  • LED/LCD
    LED technology improves regular LCD TVs through the use of LED backlighting, to create brighter, richer colors than achieved with a regular LCD TV.
  • Picture quality
    LG TVs employ a range of display technologies, which deliver brilliant colors and image clarity within each technology type.
  • Triple XD Engine
    The advanced Triple XD Engine provides the highest level of image processing that LG has to offer, to provide excellence in color, contrast and image clarity.
  • IPS panel
    LG IPS panels allow you to enjoy lifelike picture quality with minimal variation from wide viewing angles. Featuring superior consistency and less change in color temperature and contrast, LG IPS panels boast excellent image reproduction.
  • Picture Wizard II
    Picture Wizard II allows you to easily adjust picture elements such as black level, color, tint, sharpness and brightness levels to the way you prefer it.
  • Resolution upscaler
    LGs resolution upscaler improves the picture definition on any media files less than Full HD, for a more enhanced viewing experience.
  • Full HD 1080P
    Full HD TVs are double the picture definition of HD TVs, giving you a very clear image in larger screen sizes. Details are rich, gradations are smooth, giving you an outstanding picture on your LG TV.
  • DivX HD
    LG TVs are DivX Certified and can play DivX video up to 1080p HD. Enjoy the variety of Internet video created by DivX HD, on your LG TV.
  • USB movie
    Watch movies or listen to music directly from your USB stick or Hard Drive, on your TV.
  • Clear Voice II
    Clear Voice II automatically recognizes and enhances the volume of human voices in movies and shows to make them clear compared to televisions without this feature.
  • Virtual Surround Plus
    The Virtual Surround feature produces a sound effect that mimics a surround sound speaker system. Surround Sound PLUS adds an additional sound effect which gives the listener the sensation that sound is also coming down from above.
LG 32LN5400 32" LED-backlit LCD TV - Full HD
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
100 Hz Motion Clarity Index
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
1 ports
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight
Digital TV Tuner
DVB-C, DVB-S, DVB-T
USB
Remote control
Energy Class
Class A+
Power Consumption (On mode)
41 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
60 kWh
73.8 cm x 7.9 cm x 43.7 cm
6 kg
LED-backlit LCD TV
Energy Class
Class A+
41 W
60 kWh
Diagonal Class
32"
TV Tuner Presence
Video Interface
HDMI Ports Qty
1 ports
HDCP Compatible
Dimensions
Without stand
73.8 cm
7.9 cm
43.7 cm
6 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
24p Technology
24p Real Cinema
LED backlight
Widescreen Modes
Zoom 14:9, Conventional 4:3, Zoom, 16:9, Full Wide, Just Scan, Original, Cinema Zoom
Triple XD Engine
Stands & Mounts
Flat Panel Mount Interface
200 x 100 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-S, DVB-T
HDTV Tuner
Video Features
Teletext
Teletext Memory
2000 pages
Parental Channel Lock
Media Player
Supported Video Formats
DivX HD
Supported Pictures Formats
JPG, MPO
USB Port
USB Ports Qty
1
Remote Control
Remote control
Network & Internet Multimedia
Connect & Share
Mobile High-Definition Link (MHL)
Connector Type
Audio line-in - rear , HDMI - rear , USB 2.0 - side , Composite video / component video / audio input - rear , SCART - rear , Digital audio output (optical) - rear
Power supply
0.3 Watt
Dimensions & Weight Details
Panel without stand - 73.8 cm x 7.9 cm x 43.7 cm x 6 kg , Panel with stand - 73.8 cm x 20.7 cm x 49.7 cm x 6.7 kg
