LG Electronics 32LD350 32" HD 1080p LCD TV with 2 x HDMI and built in freeview
Quicklinx: 70MGWS00 Mfr#: 32LD350.AEK
  • 1080p
Sophisticated style and technology
The LG 32 inch LD350 LCD TV provides Full HD 1080p picture quality which provides up to 5 times the picture quality of standard definition.
Picture Wizard
Developed by visual specialists, LGs Picture Wizard helps you maximise the quality and settings of your TV. Whether watching sport or movies the Picture Wizard will give you complete control of your viewing pleasure making you the expert.
2 HDMI INPUTS
Connect your High Definition devices such as games console or blu-ray player through the two HDMI ports for a true High Definition multimedia experience.
HD-Ready 1080p
LG HD Ready 1080p (Full HD) provides 1920 x 1080p picture resolution delivering incredible picture clarity and vibrant colours. You'll see up to 5 times the picture clarity and detail in comparison to standard definition and double the detail compared to HD Ready 720p. 1080p television is the only way to fully experience the true potential of high definition gaming and blu-ray which takes you even closer to the action.
Freeview
All LG TVs come with built-in Digital Freeview making sure you're ready for the digital switch-over. With LG TVs you'll have access to over 40 Freeview TV and radio channels 8 day on-screen guide and access to digital interactive services.
ISF Certification
ISF Certified Calibration Controls allows LG TVs to be optimised for your specific environment. Via an optional service and ISF professional can precisely calibrate your display with customised levels of contrast, tint, colour level and other parameters to bring the picture to life.
Energy Saving Recommended
This TV has been certified by the Energy Saving Trust to save power consumption up to 20% therefore can save you money off your electricity bills.
*What are Invisible Speakers? *
Wide Sweet Spot. The front bezel works as a speaker, replacing the normal speaker grill. With the Invisible Speaker system, the speakers are embedded in strategic spots underneath and around the front bezel. They enhance the audio by increasing the `sweet spot' to give a wider and richer sound field. This new speaker system provides a clean and fashionable design compared with traditional side or bottom speaker designs.
Screen size
32"
Display Type
LCD
Full HD (1080p)
Contrast Ratio
50,000:1.
Aspect Ratio
16:9
HDMI
2
Audio Output
10W + 10W
Clear Voice
Yes (Clear Voice 2).
Smart Energy Saving Plus
Yes.
SET (w/o stand) (mm)
800 x 509 x 73.8
Including stand (mm)
800 x 565 x 206.8
VESA Dimensions (mm)
100 x 100.
SET (w/o stand kg)
8.2
