LG Electronics 32" 32SE3B 1920x1080p HD Class LCD Flat Panel Display
Installation required? Contact us today!
Quicklinx: C2SQWS00 Mfr#: 32SE3B
  • 1080p (Full HD)
Run messages on up to 50 display screens in the form of a billboard without any additional hardware. Advertisements, information and broadcast content can be arranged on the same screen to attract attention and deliver specific messaging to your customer base.
LG 32SE3B-B 32" LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi (optional)
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SNMP support, detachable logo, No Signal image, SuperSign-w lite, SuperSign-c
Speaker System
Speakers not included
USB
2 ports
Remote Control
Standard remote
Voltage
50 Watt
Power Consumption Stand by
0.7 Watt
Dimensions (WxDxH) - without stand and speakers
72.94 cm x 5.55 cm x 42.89 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
50 Watt
Diagonal Class
32"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Design
Slim Bezel Design
225
Dimensions
Without stand and speakers
72.94 cm
5.55 cm
42.89 cm
5.2 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare, 3H Hard
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
500000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Backlight Life
50,000 hour(s)
Commercial Features
Image Sticking Minimization (ISM), compatible with SuperSign Software, Enhanced Fail Over, 18/7 operation time
Stands & Mounts
Stand
Optional
VESA Mounting Interface
200 x 200 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Audio Controls
Equalizer, balance
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
Clear Voice II technology
Network & Internet Multimedia
Wi-Fi (optional)
Connector Type
HDMI input - rear , Serial input - rear , Serial output - rear , DVI-D input - rear , VGA input - rear , Network - rear , 2 x USB - rear , 2 x speakers output - rear , Remote control input - rear
Batteries
VGA cable
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
0.7 Watt
Power Consumption (Off Mode)
0.5 Watt
Smart energy saving, WOL (Wake on LAN)
Limited warranty - 3 years
Dimensions & Weight Details
Panel without stand and without speakers - 72.94 cm x 5.55 cm x 42.89 cm x 5.2 kg , Panel with stand and speakers - 72.94 cm x 154248.1 cm x 5.2 cm , Panel with stand - 6 kg
Width (Shipping)
81 cm
Depth (Shipping)
13.2 cm
Height (Shipping)
51 cm
Weight (Shipping)
6.5 kg
10 - 80%
C2SQ C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
C2SQ C2G 5m USB 2.0 A/B Cable - Black In Stock £5.14
C2SQ C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.89
C2SQ C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.13
C2SQ C2G USB Superbooster Extender Kit In Stock £38.72
C2SQ C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.94
C2SQ C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
