LG Electronics 31MU97 31" 4096x2160 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: B5ZHWS00 Mfr#: 31MU97-B
Get a wide angle viewing experience that’s rich in color and contrast. With this IPS monitor from LG, you can enjoy brilliant picture quality, outstanding color accuracy and crisp, clear images.
LG 31MU97-B - LED monitor - 31"
LED-backlit LCD monitor - 31"
Energy Class
Class B
Energy Consumption per Year
77 kWh
Power Consumption (On mode)
53 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
17:9
Native Resolution
4K UHD (2160p) 4096 x 2160 (DisplayPort: 60 Hz, HDMI: 24 Hz)
Pixel Pitch
0.1675 mm
Brightness
320 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Matte black, matte titanium
73.67 cm x 24.14 cm x 48.35 cm
9.3 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, TUV, EN 61000-3-3, EN55024, DDC/CI, EN 60950-1:2006, EN61000-3-2:2006, EN55022:2006 Class B
3-year warranty
Display Type
Energy Class
Class B
77 kWh
Diagonal Size
31"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
17:9
Native Resolution
Pixel Pitch
0.1675 mm
Brightness
320 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 134 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture by picture, sRGB colour management, Eco-Mode, Digital Fine Contrast (DFC), DICOM calibrated, SUPER Energy Saving Technology, SUPER + Resolution, Auto Resolution, Multiscan Support, TrueColor Pro, 4-screen split
73.67 cm x 24.14 cm x 48.35 cm - with stand
9.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
2 x HDMI , USB 3.0 upstream , DisplayPort , Audio line-out , 3 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+15
Swivel Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x USB cable , 1 x DisplayPort cable
Backlight Life
50,000 hours
Power Supply
Internal
Input Voltage
53 W
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 73.67 cm - depth: 24.14 cm - height: 48.35 cm - weight: 9.3 kg , Without stand - width: 73.67 cm - depth: 5.24 cm - height: 40.75 cm - weight: 7.3 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return , Limited warranty - backlight - 3 years
B5ZH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
