LG Electronics 29EB93-P 29" 2560x1080 DVI DP HDMI LED IPS Monitor
Quicklinx: 91S6WS00 Mfr#: 29EB93-P
Enjoy your movies or games with realistic stereo sound. With the built-in stereo speakers, there is no need for extra speakers around your monitor. As LG IPS monitor features consistency and less changes in color temperature, it offers a color impression identical to that of the original image. LG IPS monitor allows you to enjoy lifelike picture quality without any color shift whether you are standing or lying down. LG IPS monitor always provides clear images with smooth color changes. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort. The sRGB is the standard color space generally used in digital cameras, printers and the web design. Monitors supporting sRGB 99% offers a rich, lifelike experience with 99% sRGB color reproduction, giving you accurate color viewing when browsing photos or websites. 21:9 UltraWide screen optimizes your entertainment needs. Enjoy a theater-like experience when playing games or watching your favorite movies, which cannot be matched by conventional 16:9 screens.
  • 21:9 UltraWide screen
  • Cinema screen
    Designed with pure inspiration and cutting edge technology, the cinema screen design delivers an incredibly immersive viewing experience.
  • MHL
    MHL links your smart phone's display and sound to the 21:9 UltraWide monitor so you can enjoy content such as videos and games, with impressive scale and overwhelming sound.
  • Stereo sound
  • Lifelike color
  • Wide viewing angle
  • Smooth color change
  • sRGB 99%
LG 29EB93-P - LED monitor - 29"
LED-backlit LCD monitor - 29"
Power Consumption (On mode)
48 W
USB Hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Matte black
69.97 cm x 6.85 cm x 31.8 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, RoHS
Display Type
Diagonal Size
29"
Built-in Devices
USB Hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Picture in picture, picture by picture, Multiscan Support, CINEMA Screen Design
Matte black
69.97 cm x 6.85 cm x 31.8 cm - without stand
5.2 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
DVI-D (dual link) (HDCP) , 2 x HDMI , Audio line-in , DisplayPort , Audio line-out , 3 x USB 3.0
Mechanical
Height, tilt
Tilt Angle
-5/+23
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x USB cable , 1 x DVI cable , 1 x audio cable
Backlight Life
50,000 hours
Power Supply
Internal
Input Voltage
48 W
Power Consumption (Typical)
48 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 69.97 cm - depth: 6.85 cm - height: 31.8 cm - weight: 5.2 kg
Sustainability Information
ENERGY STAR Certified
