29EA93P provides cinematic viewing experience through the 21:9 ultra-wide aspect ratio, providing lifelike color expression on the IPS panel. It is optimal for your entertainment needs. Enjoy a theater-like experience when playing games or watching the favorite movies. Furthermore, Multitasking is simple with this monitor. Using the 4-screen split function, several applications can be simultaneously accessed simply and conveniently. It is optimal for viewing files with widely distributed information, like Excel documents.
21:9 ultra-wide screen
21:9 ultra-wide screen is also optimal for your entertainment needs. Enjoy a theater-like experience when playing games or watching your favorite movies, which cannot be matched by conventional 16:9 screens. -
Cinema screen
Designed with pure inspiration and cutting edge technology, the cinema screen design delivers an incredibly immersive viewing experience. -
Stereo sound
Enjoy your movies or games with realistic stereo sound. With the built-in stereo speakers, there is no need for extra speakers around your monitor. -
Lifelike color
As LG IPS monitor features consistency and less changes in color temperature, it offers a color impression close to that of the original image. -
Wide viewing angle
LG IPS monitor allows you to enjoy lifelike picture quality without any color shift from wide viewing angles. -
Smooth color change
LG IPS Monitor always provides clear images with smooth color changes. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort. -
SRGB 100%
sRGB is the standard color space generally used in digital cameras, printers and the web design. Monitors supporting sRGB 100% offers a rich, lifelike experience with 100% sRGB color reproduction, giving you accurate color viewing when browsing photos or websites.
- LG 29EA93-P - LED monitor - 29"
- LED-backlit LCD monitor - 29"
- Energy Class
- Class C
- Energy Consumption per Year
- 80 kWh
- Power Consumption (On mode)
- 55 W
- USB Hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (47/63 Hz)
- Matte black hairline, high gloss white with chrome stand
- 69.97 cm x 20.85 cm x 38.7 cm
- 5.65 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, UL, DDC/CI, RoHS
- 2-year warranty
- Display Type
- Energy Class
- Class C
- 80 kWh
- Diagonal Size
- 29"
- Built-in Devices
- USB Hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Picture in picture, picture by picture, Multiscan Support, CINEMA Screen Design
- 69.97 cm x 20.85 cm x 38.7 cm - with stand
- 5.65 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- DVI-D , 2 x HDMI , Audio line-in , DisplayPort , Headphones , 3 x USB
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB cable , 1 x DVI cable , 1 x audio cable
- Power Supply
- Internal
- Input Voltage
- 55 W
- Power Consumption Stand by / Sleep
- 1.2 Watt
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows Vista / 7, Windows 8
- Dimensions & Weight Details
- With stand - width: 69.97 cm - depth: 20.85 cm - height: 38.7 cm - weight: 5.65 kg , Without stand - width: 69.97 cm - depth: 6.85 cm - height: 31.8 cm - weight: 5.2 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - pick-up and return
