As LG IPS monitor features consistency and less changes in color temperature, it realize a color impression identical to its original image.
LG IPS monitor allows you to enjoy lifelike picture quality without any color shift whether you are standing or lying down.
Lifelike color
As LG IPS monitor features consistency and less changes in color temperature, it realize a color impression identical to its original image. -
Reader mode
Reducing blue light to protect your eyes, reader mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for long. -
Flicker-safe
Dimming technology is applied to minimize the flicker level causing eye fatigue. With almost-zero flicker technology, you'll be able to watch longer, comfortably. -
Wide viewing angle
LG IPS monitor allows you to enjoy lifelike picture quality without any color shift whether you are standing or lying down. -
Smooth color change
Smooth color change allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort. -
Super energy saving
LG super energy saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight has improved from 25% to 30%.
- LG 27MP35HQ-B - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 27 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.3114 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Screen Coating
- Anti-glare, 3H Hard Coating
- Matte black
- Plug and Play, DDC/CI
- Display Type
- Energy Class
- Class A
- 39 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Power off timer, HDCP, Picture Mode, SUPER Energy Saving Technology, Auto Resolution, Smooth Color Change, Lifelike Color, Dual Smart Solution
- Matte black
- VGA , HDMI (HDCP) , Headphones
- 27 W
- Power Consumption Sleep
- 0.3 Watt
