Full HD IPS display
IPS (In-Plane Switching) technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle. -
On-Screen control
On-Screen control puts a host of essential settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split and more can now be adjusted with just a few clicks of the mouse. -
Screen Split
Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices. -
Black Stabilizer
Keep visibility even in dark scenes. LG's Black Stabilizer senses dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark. -
Reader mode
Reducing blue light to help lessen eye fatigue, Reader mode provides optimal condition for reading. With just a click of a mouse, you can more comfortably read your monitor screen. -
Sleek design
The panel's slim and sleek design is about form meeting function. The reduction of panel depth adds a sharp, clean look to a workspace at the same time frees up space on your desktop. -
ArcLine stand
The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
- LG 24MP58VQ-P - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 36 kWh
- Power Consumption (On mode)
- 25 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Input Connectors
- HDMI, DVI, VGA
- Voltage
- AC 120/230 V
- Black
- Dimensions (WxDxH) - without stand
- 55.05 cm x 8.65 cm x 33.21 cm
- 2.8 kg
- Plug and Play, DDC/CI
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 36 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- SUPER Energy Saving Technology, Flicker Safe, Reader Mode, Multilingual On Screen Display, Black Stabilizer, My Display Preset, Sleek Cut Design
- Black
- 55.05 cm x 8.65 cm x 33.21 cm - without stand
- 2.8 kg
- VGA , HDMI , DVI , Headphones
- Input Voltage
- AC 120/230 V
- 25 W
- Power Consumption (Typical)
- 23 Watt
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 55.05 cm - depth: 8.65 cm - height: 33.21 cm - weight: 2.8 kg , With stand - width: 55.05 cm - depth: 18.68 cm - height: 41.9 cm - weight: 3.2 kg
- Limited warranty - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
