LG Electronics 24EN43VS 24" LED 1920x1080 VGA DVI HDMI
Quicklinx: 8P10WS00 Mfr#: 24EN43VS
Full HD
FULL HD resolution brings you magnificent picture quality through outstanding colour accuracy, visual contrast and sharpness
LED
Brilliant LED Backlighting display delivers crystal-clear images, true blacks and the most vivid, life-like colours on a slim screen
  • LED backlighting
    LG's LED technology delivers amazing brightness, clarity and color detail.
  • Full HD 1080p resolution
    This stunning picture is the reason you wanted HD in the first place. With almost double the pixel resolution, Full HD 1080p gives it superior picture quality over standard HD. You'll see details and colors like never before.
  • Super energy saving
    For conventional LED monitors, power consumption may be reduced if luminance is reduced, but the display image turns dark. LG's super energy saving technology helps to reproduce images without losing brightness while saving on overall power consumption.
  • Dual web
    Dual web makes it easy to multitask. This feature optimizes the window size to automatically divide the screen to view multiple web pages at once.
LG 24EN43VS-B - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.27675 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-reflective
Voltage
AC 120/230 V
56.7 cm x 18.1 cm x 41.8 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, cUL, DDC/CI
3-year warranty
Display Type
Energy Class
Class B
38 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27675 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-reflective
Backlight Technology
LED backlight
4:3 in Wide, SUPER Energy Saving Technology, Auto Resolution
56.7 cm x 18.1 cm x 41.8 cm - with stand
3.6 kg
VGA , DVI-D (HDCP) , HDMI , Headphones
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Power Supply
Internal
Input Voltage
AC 120/230 V
26 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 18.1 cm - height: 41.8 cm - weight: 3.6 kg , Without stand - width: 56.7 cm - depth: 5.5 cm - height: 34.3 cm - weight: 3.4 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - on-site
