LG Electronics 24" LCD Monitor 1920 x 1080 HDMI D-Sub and DVI
Quicklinx: B16SWS00 Mfr#: 24MT46D-PZ
LG IPS Personal TV provides various multimedia entertainment such as HD broadcasting, DVDs, Internet, games and photos. Your viewing pleasure is further enhanced with Full HD picture quality. As LG IPS Monitor features consistency and less changes in color temperature, it offers a color impression identical to that of the original image.
  • Smooth color change
    LG IPS always provides clear images with smooth color changes. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
  • Full HD
    Full HD resolution brings you magnificent picture quality through outstanding color accuracy, visual contrast, and sharpness.
  • Stereo speaker
    Enjoy your movies or games with realistic stereo sound. With the built in stereo speaker, there is no need for extra speakers around your monitor.
  • Time machine
    With the external storage connected, you can handily record TV program and go back to where you want to watch again.
  • PIP
    PIP indicates the way of displaying multi-screen at the same time. View and enjoy TV in a sub-screen while searching the Internet.
LG 24MT46D-PZ - LED monitor with TV tuner - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Speakers
Integrated
Digital TV Tuner
DVB-C, DVB-T
Display Position Adjustments
Tilt
Voltage
High glossy black, textured black
56.68 cm x 18.84 cm x 44.77 cm
3.9 kg
Plug and Play, TUV, DDC-2B, EN55022, EN55024, EN 6100-3-2, EN61000-3-2:2006, EN61000
Display Type
Energy Class
Class A
33 kWh
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
4:3 in Wide, SUPER Energy Saving Technology, Mega Contrast Ratio, Dolby Surround
56.68 cm x 18.84 cm x 44.77 cm - with stand
3.9 kg
TV Tuner
Digital TV
DVB-C, DVB-T
Conditional Access
Common Interface Plus (CI+) slot
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
VGA , HDMI , Component video , Composite video , SCART , USB , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+20
Backlight Life
50,000 hours
Power Supply
Internal
Input Voltage
22 W
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.68 cm - depth: 18.84 cm - height: 44.77 cm - weight: 3.9 kg , Without stand - width: 56.68 cm - depth: 6.65 cm - height: 34.61 cm - weight: 3.6 kg
Limited warranty - 2 years - pick-up and return
