LG Electronics 22MB67PY 22" 1680x1080 5ms DVI VGA LED Monitor
Quicklinx: C0N0WS00 Mfr#: 22MB67PY
The screen turn off/on automatically when the sensor detects you seat or leave in front of monitor.
Pivot & Height, Swivel and Tilt Adjustments support various work enviornment and office app template.
Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortablly read from the monitor - for as long as you want.
LG 22MB67PY - LED monitor - 22"
LED-backlit LCD monitor - 22"
USB Hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Brightness
250 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
50.6 cm x 23.9 cm x 36.5 cm
4.7 kg
Plug and Play, FCC Class B certified, UL, TUV GS, cUL, ISO 13406-2, TUV Ergo, DDC/CI, EPA
Display Type
Diagonal Size
22"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Brightness
250 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
HDCP, Flicker Safe, Reader Mode, SIX Axis Control, Smart Energy Saving technology, Intelligent Auto, Motion Energy Saver
50.6 cm x 23.9 cm x 36.5 cm - with stand
4.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D , DisplayPort , USB upstream , 2 x USB downstream , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
1 x audio cable , 1 x USB cable
Input Voltage
AC 120/230 V
Power Consumption (Typical)
33 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Windows 8
Dimensions & Weight Details
With stand - width: 50.6 cm - depth: 23.9 cm - height: 36.5 cm - weight: 4.7 kg , Without stand - width: 50.6 cm - depth: 5.8 cm - height: 33.9 cm - weight: 3.5 kg
C0N0 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.89
C0N0 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.60
