Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
LG Electronics 22M37A 22" LED 1920x1080 5ms VGA Monitor
Quicklinx: B9R3WS00 Mfr#: 22M37A-B
Reader Mode
Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortablly read from the monitor - for as long as you want.
Flicker Safe
Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers. Work and entertain as long as you want!
Colour Wizard
The Colour Wizard feature prevents colour-weak people from missing important content by distinguishing certain ranges of colours via the colour revision algorithm.
Smart Energy Saving
LG Smart Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved. * Conserve energy by adjusting screen brightness
LG 22M37A-B - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
50.9 cm x 18.1 cm x 38.7 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Backlight Technology
WLED
Dual web, Smart Energy Saving technology, Color Wizard
50.9 cm x 18.1 cm x 38.7 cm - with stand
2.6 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
Power Supply
External
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Windows 8
Dimensions & Weight Details
With stand - width: 50.9 cm - depth: 18.1 cm - height: 38.7 cm - weight: 2.6 kg , Without stand - width: 50.9 cm - depth: 5.7 cm - height: 31.6 cm - weight: 2.4 kg
Sustainability Information
ENERGY STAR Certified
