LG Electronics 22" 1920x1080 5ms VGA DVI HDMI IPS LED Monitor
Quicklinx: BCJ1WS00 Mfr#: 22MP57VQ
The LG IPS monitor ensures an awesome picture quality that provides clear images and vivid colors from any angle. LG's IPS monitor provides accurate color for your viewing pleasure.
The 4-screen split feature improves productivity by simply re-sizing the windows on your screen. With one drag you can re-size one window and the other windows automatically to fir the available space. It allows from 2 to 4 windows to be shown in 8 diffferent screen ratios without feeling cluttered.
The color wizard feature prevents color-weak people from missing important content by distinguishing certain ranges of colors via the color revision algorithm.
  • IPS display
  • 4-screen split
  • Color wizard
  • Flicker safe
    Reducing the flicker level to almost zero, flicker-safe helps you protect your eyes from exhausting flickers. Work and entertain as long as you want with the IPS monitor.
  • Reader mode
    Reader mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortably read from the monitor - for as long as you want.
LG 22MP57VQ - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
51 cm x 19.5 cm x 41.1 cm
2.7 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, EPA 6.0
Display Type
Energy Class
Class B
35 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
HDCP, SUPER + Resolution, Smart Energy Saving technology, Color Wizard
51 cm x 19.5 cm x 41.1 cm - with stand
2.7 kg
HDMI , DVI-D (HDCP) , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
Power Supply
External
24 W
Dimensions & Weight Details
With stand - width: 51 cm - depth: 19.5 cm - height: 41.1 cm - weight: 2.7 kg , Without stand - width: 51 cm - depth: 6.5 cm - height: 31.4 cm - weight: 2.5 kg
