LG Electronics 2.1 Bluetooth 320W HDMI Soundbar
Quicklinx: BH24WS00 Mfr#: LAS550H
Kick back, relax and immerse yourself with a 2.1 Ch surround sound speaker system which brings to life all of your favorite movies, music, soaps and shows.
Play your favorite music from your smartphone or Bluetooth enabled device on your LG soundbar by wirelessly streaming via Bluetooth.
  • Surround your senses with sound
  • Update manager
    Always keep your sound bar up-to-date with the firmware options that can all be updated from your smart devices wirelessly.
  • Wireless audio streaming via Bluetooth
  • Active wireless subwoofer
    Free your living room from wires. LG's active wireless subwoofer allows you to enjoy superb sound quality without compromising on design.
  • Mood station
    LGs Mood Matrix recommends songs to match your current mood or activity and can automatically create playlists.
LG LAS550H - sound bar system - wireless
Sound bar system - 2.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Enclosure Design
Bass reflex
Speaker Type
Active
Nominal Output Power (Total)
320 Watt
Amplifier
Integrated
Bluetooth
Audio Formats
WAV, WMA, MP3, FLAC, LPCM, OGG
Speaker System Details
1 x sound bar 120 Watt , 1 x subwoofer 200 Watt
Speaker Details
Sound bar - stereo x 2 - 60 Watt - at 1 kHz - 10% THD - 2-way - active , Speaker - subwoofer - at 80 Hz - 10% THD - 3 Ohm - active
Built-in Decoders
Dolby Digital, DTS decoder, SBC decoder
Sound Effects
Vertical Surround, Sound Sync
Power Options
Auto power on/off
1-year warranty
USB-host
Enclosure Design
Bass reflex
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
320 Watt
Amplifier
Integrated
Sound Effects
Audio Return Channel (ARC) Capability
Bluetooth 4.0
Built-in Decoders
Audio Formats
Controls
EQ mode selector, volume, treble, bass
Additional Features
Bi-amplified, Audio Return Channel (ARC), night mode, SIMPLINK technology
Speakers Included
1 x sound bar - 2-way - 120 Watt - wall-mountable - wireless , 1 x subwoofer - 200 Watt - wireless
Speaker Details
Sound bar - stereo x 2 - 60 Watt - at 1 kHz CFR - 10% THD - 2-way - active , Speaker - subwoofer - at 80 Hz CFR - 10% THD - 3 Ohm - active
Driver Details
Sound bar: 2 x woofer driver - 1.57 x 3.94" , Sound bar: 2 x tweeter driver - 0.79"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 6"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link) , USB (4 PIN USB Type A) , HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A)
Power adapter, remote control, wall mounting kit
Power Source
AC power adapter
Options
Auto power on/off
Dimensions (WxDxH) / Weight Details
Sound bar: 89 cm x 8.5 cm x 5.1 cm / 2.8 kg , Subwoofer: 17.1 cm x 39 cm x 26.1 cm / 5.6 kg
Limited warranty - parts and labour - 1 year
