LG Electronics 10x Internal BDRW SATA Retail Kit
Quicklinx: 7RPDWS00 Mfr#: BH10LS38.AUAR
  • BD-RE
Read and write Blu-ray discs at 10x with the BH10LS38 Blu-ray re-writer that allows you to record up to 50GB of files, photos or business documents onto a single dual layer BD-R disc.
Key Features
  • 10x BD-R read and write capability
  • SATA interface
  • LightScribe direct disc labelling
  • 16x DVD-R write speed
  • 2MB buffer under-run prevention
Play HD content from BD Video discs or record up to nine hours of high definition video.
SATA interface technology allows for easier integration and ultimately faster performance while LightScribe gives you the added feature of etching customized labels onto a special coated LightScribe disc (sold separately).
Get into Blu with the BH10LS38 by LG.
  • Blu-Ray
    Blu-Ray Disc is the next generation in optical storage, offering 25 GB and 50 GB of storage capacity on a disc.
  • Serial ATA technology
    Serial ATA is a 1.5 Gbps evolutionary replacement for the Parallel ATA physical storage interface used to connect storage devices, such as hard disks, DVD and CD rewriters to the PC motherboard. Serial ATA is scalable, enables design of smaller PCs, and will allow future enhancements to the computing platform.
  • LightScribe technology
    LightScribe gives you the ability to create customized labels that are etched directly onto a special coated LightScribe disc.
LG BH10LS38 Super Multi Blue - BD-RE drive - Serial ATA - internal
BD-RE drive - internal
Serial ATA
14.6 cm x 17.2 cm x 4.1 cm
0.8 kg
Optical Storage
BD-RE - 5.25" x 1/2H
Read Speed
48x (CD) / 16x (DVD) / 10x (BD)
Write Speed
48x (CD) / 16x (DVD±R) / 8x (DVD±R DL) / 10x (BD-R)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM) / 2x (BD-RE)
Disc Labeling Technology
LightScribe Technology
Media Load Type
Tray
Microsoft Certification
Compatible with Windows 7
Serial ATA
14.6 cm
17.2 cm
4.1 cm
0.8 kg
Optical Storage
Read Speed
Write Speed
Supported Media Formats
CD-ROM
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-RE, BD-ROM
Media Load Type
Tray
Access Time
160 ms (DVD), 150 ms (CD), 180 ms (BD)
Buffer Size
4 MB
1 x Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x 5.25" x 1/2H - front accessible
Package Type
Retail
Software Included
Cyberlink PowerDVD
