LG E2210PM-BN - LCD display - TFT - WLED - 22" - widescreen - 1680 x 1050 - 250 cd/m2
Quicklinx: 7V3JWS00 Mfr#: E2210PM-BN
The LG E10 series business monitor holds the key to business competitiveness. The high resolution LED brings up work efficiency, whereas the energy saving function brings down the expenses. The ergonomic design and space saving function offers the utmost optimized business environment guaranteeing a heightened business edge for your company.
  • Energy saving
    E10 series proudly presents its LED backlight features of low heat generation, long life span and high energy efficiency, which will save you up to 40% of power consumption.
  • Ergonomic design
    The monitor can be rotated 90° with the pivot. The function is convenient for checking vertical images and documents such as posters. Height, tilt, and swivel functions are also supported so that the users can adjust the monitor's height and angle to optimize their work environment.
  • Mega contrast ratio
    It offers excellent picture quality that can be realized by LED technology by showing sharper contrast of brightness and darkness.
  • Eco-friendly
    E10 series is an eco-friendly monitor that understands your concerns for health and environment. Free of hazardous substances such as halogen and mercury, LED backlight minimizes industrial waste.
LG E2210PM-BN - LED monitor - 22"
LED-backlit LCD monitor - 22"
Stereo speakers
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, pivot (rotation), tilt
Voltage
AC 120/230 V (47 - 63 Hz)
Matte black
50.6 cm x 21 cm x 48 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, DDC/CI
Display Type
Diagonal Size
22"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
H/V position
OSD-Digital Display Director, f-ENGINE technology, HDCP, Super LED Backlighting
Matte black
50.6 cm x 21 cm x 48 cm - with stand
4.2 kg
VGA , DVI-D , Headphones
Mechanical
Tilt Angle
20
Height Adjustment
100 mm
MTBF
50,000 hour(s)
TUV GS, DDC/CI
Input Voltage
Power Consumption (Typical)
26.3 Watt
Power Consumption Stand by / Sleep
0.2 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 50.6 cm - depth: 21 cm - height: 48 cm - weight: 4.2 kg , Without stand - weight: 3.2 kg
Sustainability Information
ENERGY STAR Certified
