LG Commercial Lite 65UV341C 65" 4K UHD Hospitality TV
Quicklinx: DPWNWS00 Mfr#: 65UV341C
LG Commercial Lite TVs are designed specifically for diverse business environments. Especially via compatibility with AV Control system and DPM (Display Power Management) as well as its smart connectivity, simple user friendly interface, and ULTRA HD picture quality, the UV341C series enhances the ease of use while facilitating communications between businesses and their target audiences. Also, managers can improve management efficiency by using management features such as WOL (Wake On LAN), SNMP (Simple Network Management Protocol).
  • 4K upscaler
    Enjoy Full HD content in ULTRA HD quality. The 4K Upscaler automatically upgrades Full HD content to ULTRA HD through the six steps of the upscaling processes.
  • Compatibility with AV control system
    The LG UV341C series is compatible with AV control system, with which users can easily manage, monitor and control LG commercial displays from one location.
  • DPM (Display Power Management)
    From now on, you can configure the DPM (Display Power Management) function by setting the function to on. When there is no signal, the TVs enters to DPM mode to manage power efficiently.
  • WOL (Wake on LAN)
    WOL (Wake on LAN) helps you remotely turn on TVs over the internet. Connect TVs and a PC in the same network, and send Magic Packet program to the MAC addresses of registered TVs. Then, it will wake up the TVs via LAN port.
  • SNMP
    SNMP (Simple Network Management Protocol) ensures convenient network management for SI and business managers.
  • RS-232C control
    Via the TV's RS-232C port, you can remotely control power and volume settings simultaneously.
  • Bluetooth sound sync
    This feature allows guests to listen to audio from a Bluetooth-enabled mobile device through the TV's speakers.
LG Commercial Lite 65UV341C UV341C - 65" LED-backlit LCD TV - 4K - for hotel / hospitality
LED-backlit LCD TV - Smart TV
Diagonal Class
65"
Commercial Use
Yes - hotel / hospitality
Platform
webOS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
24p Technology
24p Real Cinema
Video Interface
HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Analogue TV Tuner
PAL, SECAM
Internet Streaming Services
YouTube
Commercial Features
Screen welcome message, Multi remote control, Lock Mode, SNMP support, Self Diagnostics, Smart UX, Essential Smart, Display Power Management (DPM), Commercial Smart Home
Settings Cloning Capability
Picture Enhancements
Triple XD Engine, 4K Upscaling
Speaker System
2 speakers
USB
Voltage
Energy Class
Class A++
161.9 Watt
Power Consumption (On mode)
82 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
120 kWh
134.5 cm x 33.59 cm x 83.5 cm
22.8 kg
Energy Class
Class A++
161.9 Watt
82 W
120 kWh
Diagonal Class
65"
Commercial Use
Series
UV341C
Platform
webOS
Operating System
webOS 3.0
TV Tuner Presence
Video Interface
HDMI
HDMI Ports Qty
3 ports
Modes
Hotel mode
Dimensions
With stand
134.5 cm
33.59 cm
83.5 cm
22.8 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
24p Technology
24p Real Cinema
Edge-lit LED
Brightness
330 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:3
Response Time
8 ms
Commercial Features
One Channel Map, security lock slot (cable lock sold separately), RJP Compatible, Motion eye care, Soft AP, Crestron Connected Compatible
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Analogue Video Input Signals
PAL, SECAM
Media Player
USB Port
USB Ports Qty
1
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Bluetooth Sound Sync, Clear Voice III technology, LG Sound Sync
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
Wi-Fi, LAN
Connect & Share
Wi-Fi Miracast, Smart Share, Screen Share
YouTube
Connector Type
Serial input - rear , LAN - rear , Digital audio output (optical) - rear , HDMI - rear , Service - rear , Headphones - rear , 2 x HDMI - side , USB 2.0 - side
CB, RoHS, ERP, CU-TR
Power supply
Input Voltage
0.3 Watt
Smart energy saving, WOL (Wake on LAN)
Width (Shipping)
149.2 cm
Depth (Shipping)
19 cm
Height (Shipping)
88 cm
Weight (Shipping)
29.3 kg
