Viewers can be annoyed by unnecessary reflections when watching a screen under brightly lit conditions. The UH5F-H series has resolved such inconveniences by increasing the level of haze, which enhances visibility and text readability.
With the resolution that is 4 times higher than FHD, it makes the color and details of the contents more vivid and realistic. In addition, the wide viewing angle applied with an IPS panel, provides clear contents with no distortion.
Built-in Quad Core SoC can execute several tasks at once while providing smooth content playback without the need for a media player. Also, LG webOS smart signage platform enhances user convenience with intuitive GUI and simple app development tools.
LG webOS smart signage platform easily supports connections with external sensors such as GPIO, NFC/RFID, temperature sensors, etc, via USB plug-in. The overall cost for maintenance is reduced as there's no need to purchase additional software or media players for creating value-added solutions.
The UH5F-H series has been certified Crestron Connected for high compatibility with professional AV controls to achieve seamless integration and automated control, boosting business management efficiency.
For the optimum visual meeting, the UH5F-H series has certified its compatibility with Cisco System that offers powerful and integrated control for a smarter video conference, eliminating a waste of time for setting up the picture quality or changing input on incoming calls.
Clear view with non-glare coating
Viewers can be annoyed by unnecessary reflections when watching a screen under brightly lit conditions. The UH5F-H series has resolved such inconveniences by increasing the level of haze, which enhances visibility and text readability. -
ULTRA HD resolution
With the resolution that is 4 times higher than FHD, it makes the color and details of the contents more vivid and realistic. In addition, the wide viewing angle applied with an IPS panel, provides clear contents with no distortion. -
High-performance with webOS
Built-in Quad Core SoC can execute several tasks at once while providing smooth content playback without the need for a media player. Also, LG webOS smart signage platform enhances user convenience with intuitive GUI and simple app development tools. -
Various sensor applications
LG webOS smart signage platform easily supports connections with external sensors such as GPIO, NFC/RFID, temperature sensors, etc, via USB plug-in. The overall cost for maintenance is reduced as there's no need to purchase additional software or media players for creating value-added solutions. -
Compatible with AV control system
The UH5F-H series has been certified Crestron Connected for high compatibility with professional AV controls to achieve seamless integration and automated control, boosting business management efficiency. -
Compatible with video conference system
For the optimum visual meeting, the UH5F-H series has certified its compatibility with Cisco System that offers powerful and integrated control for a smarter video conference, eliminating a waste of time for setting up the picture quality or changing input on incoming calls. -
Real-time monitoring & control
Through the Control Manager, the embedded web monitoring solution, you can control and monitor the status of multiple UH5F-H series displays in different locations in real-time. It is available on internet connected devices, allowing you to flexibly and rapidly respond to emergency situations anywhere. -
Multiscreen feature with PBP / PIP
PBP (Picture-By-Picture) features multiple screens in a single display with up to 4 input sources while PIP (Picture-In-Picture) supports playing both a main screen and a subscreen at the same time with various layouts. This gives great flexibility to allocate space for each content source. -
Wireless Access Point
The UH5F-H series operates as a virtual router which can be a wireless access point for mobile devices.
- LG 65UH5F-H UH5F-H Series - 65" LED-backlit LCD display - 4K - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- LAN
- PC Interface
- DVI, DisplayPort
- Technology
- IPS
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform, detachable logo, LG SuperSign Media Editor, SuperSign CMS compatible, SuperSign Control+ compatible, SuperSign Control compatible, SuperSign WB compatible
- Picture Enhancements
- 95% Colour Gamut
- USB
- Included Accessories
- Remote control
- Voltage
- AC 100-240 V (50/60 Hz)
- Energy Class
- Class G
- 120 watt
- Dimensions (WxDxH) - without stand
- 145.33 cm x 3.99 cm x 84.4 cm
- 28.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class G
- Power Consumption (Max)
- 165 watt
- 120 watt
- Power Consumption SDR (On mode)
- 133 kWh/1000h
- Diagonal Class
- 65"
- Commercial Use
- Series
- UH5F-H Series
- Operating System
- webOS
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- PC Interface
- DVI, DisplayPort
- Modes
- Portrait mode, landscape mode
- 95% Colour Gamut
- Dimensions
- Without stand
- 145.33 cm
- 3.99 cm
- 84.4 cm
- 28.2 kg
- Enclosure Colour
- Black
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Coating
- Anti-glare, 28% haze
- Image Contrast Ratio
- 1100:1
- Dynamic Contrast Ratio
- 1000000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Operation Hours / Days
- 24 / 7
- 10-bit support, picture in picture (no tuner), picture by picture (no tuner), wireless access point
Stands & Mounts
- Flat Panel Mount Interface
- 300 x 300 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 1
- Configuration
- Quad-Core
Remote Control
- Remote control
Audio System
- Built-in speaker
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- 3 x HDMI input , DisplayPort input , DVI-D input , Audio line-in , USB 2.0 , DisplayPort output , Audio line-out , RS-232C input/output , Remote control , Infrared input
- Cables Included
- HDMI cable , Serial adapter
- FCC Class A certified, CB, EMC, KC, ERP, NRTL, IP5X, HDCP 2.2, HDCP 1.3, HDCP 1.4
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power supply
- Input Voltage
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.33 cm x 3.99 cm x 84.4 cm x 28.2 kg , Panel with stand - 145.33 cm x 29 cm x 89.31 cm
- 0 °C
- 40 °C
- 10 - 80%
