LG 65UH5F-H 65" 3840x2160 8ms HDMI DisplayPort IPS Digital Signage Display
Quicklinx: H2VBWS00 Mfr#: 65UH5F-H
Viewers can be annoyed by unnecessary reflections when watching a screen under brightly lit conditions. The UH5F-H series has resolved such inconveniences by increasing the level of haze, which enhances visibility and text readability.
With the resolution that is 4 times higher than FHD, it makes the color and details of the contents more vivid and realistic. In addition, the wide viewing angle applied with an IPS panel, provides clear contents with no distortion.
Built-in Quad Core SoC can execute several tasks at once while providing smooth content playback without the need for a media player. Also, LG webOS smart signage platform enhances user convenience with intuitive GUI and simple app development tools.
LG webOS smart signage platform easily supports connections with external sensors such as GPIO, NFC/RFID, temperature sensors, etc, via USB plug-in. The overall cost for maintenance is reduced as there's no need to purchase additional software or media players for creating value-added solutions.
The UH5F-H series has been certified Crestron Connected for high compatibility with professional AV controls to achieve seamless integration and automated control, boosting business management efficiency.
For the optimum visual meeting, the UH5F-H series has certified its compatibility with Cisco System that offers powerful and integrated control for a smarter video conference, eliminating a waste of time for setting up the picture quality or changing input on incoming calls.
  • Clear view with non-glare coating
  • ULTRA HD resolution
  • High-performance with webOS
  • Various sensor applications
  • Compatible with AV control system
  • Compatible with video conference system
  • Real-time monitoring & control
    Through the Control Manager, the embedded web monitoring solution, you can control and monitor the status of multiple UH5F-H series displays in different locations in real-time. It is available on internet connected devices, allowing you to flexibly and rapidly respond to emergency situations anywhere.
  • Multiscreen feature with PBP / PIP
    PBP (Picture-By-Picture) features multiple screens in a single display with up to 4 input sources while PIP (Picture-In-Picture) supports playing both a main screen and a subscreen at the same time with various layouts. This gives great flexibility to allocate space for each content source.
  • Wireless Access Point
    The UH5F-H series operates as a virtual router which can be a wireless access point for mobile devices.
LG 65UH5F-H UH5F-H Series - 65" LED-backlit LCD display - 4K - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
DVI, DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, detachable logo, LG SuperSign Media Editor, SuperSign CMS compatible, SuperSign Control+ compatible, SuperSign Control compatible, SuperSign WB compatible
Picture Enhancements
95% Colour Gamut
USB
Remote control
Voltage
AC 100-240 V (50/60 Hz)
Energy Class
Class G
120 watt
145.33 cm x 3.99 cm x 84.4 cm
28.2 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class G
Power Consumption (Max)
165 watt
120 watt
133 kWh/1000h
Diagonal Class
65"
Commercial Use
Series
UH5F-H Series
Operating System
webOS
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode
95% Colour Gamut
Dimensions
Without stand
145.33 cm
3.99 cm
84.4 cm
28.2 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 28% haze
Image Contrast Ratio
1100:1
Dynamic Contrast Ratio
1000000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
Operation Hours / Days
24 / 7
10-bit support, picture in picture (no tuner), picture by picture (no tuner), wireless access point
Stands & Mounts
Flat Panel Mount Interface
300 x 300 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
1
Configuration
Quad-Core
Remote Control
Remote control
Audio System
Built-in speaker
Network & Internet Multimedia
LAN
Connector Type
3 x HDMI input , DisplayPort input , DVI-D input , Audio line-in , USB 2.0 , DisplayPort output , Audio line-out , RS-232C input/output , Remote control , Infrared input
HDMI cable , Serial adapter
FCC Class A certified, CB, EMC, KC, ERP, NRTL, IP5X, HDCP 2.2, HDCP 1.3, HDCP 1.4
Sustainability Information
ENERGY STAR Certified
Power supply
Input Voltage
Dimensions & Weight Details
Panel without stand - 145.33 cm x 3.99 cm x 84.4 cm x 28.2 kg , Panel with stand - 145.33 cm x 29 cm x 89.31 cm
10 - 80%
