65" LG ULTRA HD 4K TV
Key Features
IPS 4K Display
Active HDR
True Colour Accuracy
ThinQ AI
Ultra Surround
Metal Frame Design
A New Standard of Definition.
A new depth of detail. ULTRA HD 4K resolution is four times that of Full HD producing brilliant clarity and vivid details that amaze, even when viewed up close. This level of detail is well suited to modern home entertainment, sports and gaming; the resulting images will redefine your viewing experience.
Experience 4K Ultra HD on BT TV
With up to four times the detail of High Definition, 4K Ultra HD makes you feel like you’re right in the heart of the action.
BT Sport in 4K Ultra HD has to be seen to be believed, and the only place to experience it is BT TV. We bring you the UEFA Champions League, Premier League, UEFA Europa League and the Emirates FA Cup as you’ve never seen them before.
All of the 4K Ultra HD TVs we sell here on BT Shop are guaranteed to work with your BT TV service to deliver amazing 4K content. BT Sport in 4K Ultra HD and our YouView Ultra HD box is included with the Max TV package, which is available to customers with BT Infinity broadband. The only other thing you’ll need is this 4K Ultra HD TV.
If you don't already have BT TV, or haven't upgraded to receive BT Sport in 4K Ultra HD, you'll need to head over to bt.com now to order these services:
Pumped up resolution and color
This LG TV supports many premium content choices, all optimized with scene-by-scene picture adjustment. -
Brighter the better
Picture quality becomes even more dynamic with Ultra Luminance, which boosts peak brightness and increases the overall contrast ratio to give movies and TV shows a bold appearance not previously possible.
- LG 65UK6500 65" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 65"
- Platform
- webOS, LG ThinQ AI
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Format
- HDR10, HLG10
- HDR Technology
- 4K Active HDR
- Frame Rate & Enhancement Technology
- 200 Picture Mastering Index, TruMotion 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED local dimming
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Internet Streaming Services
- HbbTV, Magic Link
- Picture Enhancements
- 4K Upscaling, Dynamic Colour Enhancer, True Colour Accuracy, Wide Colour Gamut, Enhanced Dynamic Tone Mapping
- Speaker System
- 2 speakers
- Sound Effects
- ULTRA Surround
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 100 - 240 V (50/60 Hz)
- Energy Class
- Class A+
- Power Consumption (On mode)
- 118 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 164 kWh
- Dimensions (WxDxH) - without stand
- 145.6 cm x 6.5 cm x 84.1 cm
- 26 kg
- Product Type
- Energy Class
- Class A+
- 118 W
- 164 kWh
- Diagonal Class
- 65"
- Platform
- HDR Capable
- HDR Format
- HDR10, HLG10
- HDR Technology
- 4K Active HDR
- Video Processor
- Quad-Core
- TV Tuner Presence
- Sensors
- Illuminance green sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Dimensions
- Without stand
- 145.6 cm
- 6.5 cm
- 84.1 cm
- 26 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Edge-lit LED - local dimming
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 300 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Digital Audio Format
- DTS-HD digital output
- Surround Mode
- Sound Effects
- ULTRA Surround
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC), apt-X Encoder, LG Sound Sync, Adaptive Sound Control
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Connect & Share
- Screen Share
- HbbTV, Magic Link
- Supported Consumer Electronics Control (CEC)
- Simplink
- Connector Type
- 2 x HDMI - rear , 2 x HDMI - side , USB - rear , USB - side , Composite video / component video input - rear , LAN - rear , Digital audio output (optical) - rear
- Batteries
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.6 cm x 6.5 cm x 84.1 cm x 26 kg , Panel with stand - 145.6 cm x 26.9 cm x 90.6 cm x 26.3 kg
- Width (Shipping)
- 160 cm
- Depth (Shipping)
- 17.5 cm
- Height (Shipping)
- 97 cm
- Weight (Shipping)
- 32.8 kg
