LG 55SM5KE 55" 1920x1080 DVI-D HDMI LED Large Format Display
Quicklinx: F806WS00 Mfr#: 55SM5KE
Video Interface: HDMI
TV Tuner Presence: No
  • 1080p
£894.12 ex VAT
£1,072.94 inc VAT
Embedded CMS (Content Management System) allows users to edit and play content, and create playlists, all without a seperate PC. It's a one-stop solution that lets users manage signage simply, and effectively. Various types of IP video streaming protocols such as RTSP/RTP/HLS and UDP Multicast are supported for real-time content streaming. It is easy to manage content as it is free from capacity limits for content playback, and provides live broadcasts.
During playback of diverse content such as videos, images, and HTML, enjoy seamless transition between screens with no black screen gaps with webOS. PBP (Picture-By-Picture) and PIP (Picture-In-Picture) enables up to two divided split screens in landscape or portrait display format enabling users to more flexibly allocate space for each content source.
The detachable logo allows for installation in the desired orientation: landscape or portrait mode. Also, sounds can be played from built-in speakers, giving advertisements greater impact.
  • High performance smart platform
    Quad Core SoC (System-on-Chip) executes several tasks at once with smooth content playback without a media player. webOS smart signage platform enhances user convenience with intuitive UI and simple development tools.
  • Easy Contents Management
  • Real-time streaming
  • Seamless content playback
  • Multiple screen cjmposition
  • Suited for industrial design
LG 55SM5KE SM5KE Series - 55" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display - Smart TV
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/385481
Diagonal Class
55"
Commercial Use
Yes - digital signage
Platform
webOS
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
3 ports
Wi-Fi, Bluetooth
PC Interface
DVI, DisplayPort
IPS
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
HTML5 support, SNMP support, detachable logo, Smart Platform, SuperSign CMS compatible, SuperSign Control+ compatible, Embedded Content Management
Settings Cloning Capability
Speaker System
2 speakers
Platform
Crestron
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
USB
Remote control
Voltage
Energy Class
Class G
115 Watt
Power Consumption (On mode)
135 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
130 kWh
123.8 cm x 5.4 cm x 71.49 cm
17.5 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class G
115 Watt
135 W
135 kWh/1000h
130 kWh
Diagonal Class
55"
Commercial Use
Series
SM5KE Series
Platform
webOS
Operating System
webOS 4.0
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, auto brightness sensor, current sensor
Video Interface
HDMI
HDMI Ports Qty
3 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode, Tile Mode
Dimensions
Without stand
123.8 cm
5.4 cm
71.49 cm
17.5 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 3H Hard, conformal, 1% haze
Image Contrast Ratio
1100:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Backlight Life
50,000 hour(s)
Commercial Features
Operation Hours / Days
24 / 7
BEACON technology, Front Polarizer, picture in picture (no tuner), picture by picture (no tuner), wireless access point
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
300 x 300 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
1
Configuration
8 GB
8 GB
Remote Control
Remote control
Battery Included Qty
2
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi, Bluetooth
Connect & Share
Content Share, Screen Share
Connector Type
3 x HDMI input , DisplayPort input , DVI-D input , Audio line-in , USB 3.0 , DisplayPort output , Audio line-out , Serial input , Serial output , LAN , Infrared (IrDA)
Internet of Things (IoT)
Platform
Crestron
Communications Technology
Bluetooth Low Energy (LE)
HDMI cable , Serial adapter
FCC Class A certified, EMC, UL 60950-1, IEC 60950-1, EN 60950-1, KC
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Input Voltage
0.5 Watt
Smart energy saving
Dimensions & Weight Details
Panel without stand - 123.8 cm x 5.4 cm x 71.49 cm x 17.5 kg , Panel with stand - 123.8 cm x 21.96 cm x 77.34 cm x 20.8 kg
Width (Shipping)
133 cm
Depth (Shipping)
17 cm
Height (Shipping)
80.7 cm
Weight (Shipping)
21.7 kg
10 - 80%
Brand: LG
Price Range Ex VAT: £750 - £1000
