50" LG ULTRA HD 4K TV
Key Features
Active HDR
True Colour Accuracy
ThinQ AI
Ultra Surround
Metal Frame Design
Smart TV webOS
A New Standard of Definition.
A new depth of detail. ULTRA HD 4K resolution is four times that of Full HD producing brilliant clarity and vivid details that amaze, even when viewed up close. This level of detail is well suited to modern home entertainment, sports and gaming; the resulting images will redefine your viewing experience.
Experience 4K Ultra HD on BT TV
With up to four times the detail of High Definition, 4K Ultra HD makes you feel like you’re right in the heart of the action.
BT Sport in 4K Ultra HD has to be seen to be believed, and the only place to experience it is BT TV. We bring you the UEFA Champions League, Premier League, UEFA Europa League and the Emirates FA Cup as you’ve never seen them before.
All of the 4K Ultra HD TVs we sell here on BT Shop are guaranteed to work with your BT TV service to deliver amazing 4K content. BT Sport in 4K Ultra HD and our YouView Ultra HD box is included with the Max TV package, which is available to customers with BT Infinity broadband. The only other thing you’ll need is this 4K Ultra HD TV.
If you don't already have BT TV, or haven't upgraded to receive BT Sport in 4K Ultra HD, you'll need to head over to bt.com now to order these services:
An advanced standard of definition
ULTRA HD 4K resolution is four times that of Full HD producing brilliant clarity and vivid details that amaze, even when viewed up close. This level of detail is well suited to modern home entertainment, sports and gaming; the resulting images will redefine your viewing experience. -
A vibrant and vivid picture from any angle
The Ultra HD innovation is built into the unique 4K panel meaning your entertainment is viewable from any angle without distortion. -
More power to process
To support the advanced picture processing required for bright, sharp 4K images there are 4 cores of processing power available at the heart of this LG TV. A fast and powerful brain to make sure you have the best possible picture. -
Ultra luminance - the science of light control
Enjoy brighter whites and darker blacks thanks to local dimming technology which lifts the brightest scenes to brilliant levels and the darkest shadows to life. -
The ultimate HDR 4K picture
This advanced HDR technology can adapt to a variety of HDR formats and provides scene by scene image mastering, delivering pinpoint picture reproduction. Active HDR is better HDR. -
Multi-channel bringing encapsulating sound effect
Great television deserves great audio. This sound technology creates virtual multi channels which produce the ultra surround effect.
- LG 50UK6500 50" LED TV
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 50"
- Platform
- LG ThinQ AI, webOS 4.0
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Technology
- Hybrid Log-Gamma (HLG), HDR Effect, HDR 10 Pro, 4K Active HDR
- Motion Enhancement Technology
- 1700 Picture Mastering Index, 50 Hz Native Refresh Rate, TruMotion 100
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- LED backlight - direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Internet Streaming Services
- HbbTV, Magic Link
- Picture Enhancements
- 4K Upscaling, Dynamic Colour Enhancer, Noise Reduction, True Colour Accuracy, Wide Colour Gamut, Enhanced Dynamic Tone Mapping
- Speaker System
- 2 speakers
- Sound Effects
- ULTRA Surround
- USB
- 2 ports
- Remote Control
- Standard remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- Power Consumption (On mode)
- 89 W
- Energy Consumption per Year
- 123 kWh
- Dimensions (WxDxH) - without stand
- 112.8 cm x 8.6 cm x 65.8 cm
- 11.5 kg
- 1 year warranty
- Product Type
- Energy Class
- Class A
- 89 W
- 123 kWh
- Diagonal Class
- 50"
- Platform
- HDR Capable
- HDR Technology
- TV Tuner Presence
- Sensors
- Illuminance green sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Dimensions
- Without stand
- 112.8 cm
- 8.6 cm
- 65.8 cm
- 11.5 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Display Menu Language
- Multilingual
- Time-shift, Quad-Core processor, My Channel, Ultra Luminance
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- HEVC, VP9
- Supported Audio Formats
- MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS, MP2
- USB Port
- USB Ports Qty
- 2
Remote Control
- Standard remote
- LG Magic Motion Remote Control Ready
Audio System
- Digital Audio Format
- DTS-HD digital output
- Surround Mode
- Sound Effects
- ULTRA Surround
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Audio Return Channel (ARC), apt-X technology, Clear Voice III technology, LG Sound Sync, Adaptive Sound Control, Audio Upscaler
- Speakers
- 2 x speaker - built-in - 10 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Connect & Share
- Screen Mirroring, Wi-Fi Miracast, Screen Share
- HbbTV, Magic Link
- Supported Consumer Electronics Control (CEC)
- Simplink
- DLNA
- Connector Type
- 2 x HDMI - rear , 2 x HDMI - side , USB - rear , USB - side , Composite video / component video input - rear , Network - rear , Digital audio output (optical) - rear
- Included Accessories
- Batteries
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 112.8 cm x 8.6 cm x 65.8 cm x 11.5 kg , Panel with stand - 112.8 cm x 23.1 cm x 71.6 cm x 11.7 kg
- Width (Shipping)
- 121.5 cm
- Depth (Shipping)
- 16.2 cm
- Height (Shipping)
- 77.5 cm
- Weight (Shipping)
- 14.3 kg
