49" LG Full HD LED TV
Key Features
Picture Mastering Engine
Improve any image with Resolution Upscaler
Virtual Surround Sound
USB Connectivity
Built-in Games
Advanced image mastering of the color, contrast and clarity produces sharp, refined images for your entertainment. Enjoy any image with LG's resolution upscaler, which enhances and optimizes the image no matter the picture quality.
Picture mastering engine
Advanced image mastering of the color, contrast and clarity produces sharp, refined images for your entertainment. -
Improve any image with resolution upscaler
Enjoy any image with LG's resolution upscaler, which enhances and optimizes the image no matter the picture quality. -
Virtual surround sound
High quality software creates a surround sound effect producing virtual audio channels for broadcast and digital programs. Surround your senses with sound from all angles. -
USB connectivity
Simply insert a USB stick or external hard drive containing videos, photos and music into the USB port to play and view the files.
- LG 49LJ515V 49" LED-backlit LCD TV - Full HD
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 49"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 2 ports
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S2, DVB-T2
- Picture Enhancements
- Resolution Upscaler, Color Master Engine, 2K Upscaling
- Speaker System
- 2 speakers
- Sound Effects
- Virtual Surround Mode
- USB
- Included Accessories
- Batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A++
- Power Consumption (On mode)
- 45 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 62 kWh
- Dimensions (WxDxH) - without stand
- 110.8 cm x 8.2 cm x 65.7 cm
- 10.6 kg
- Product Type
- Energy Class
- Class A++
- 45 W
- 62 kWh
- Diagonal Class
- 49"
- TV Tuner Presence
- Video Interface
- HDMI Ports Qty
- 2 ports
- Dimensions
- Without stand
- 110.8 cm
- 8.2 cm
- 65.7 cm
- 10.6 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 300 mm
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- HEVC
- Supported Audio Formats
- MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, MP2
- USB Port
- USB Ports Qty
- 1
Audio System
- Surround Mode
- Sound Effects
- Speaker System
- 2 speakers
- Output Power / Total
- 10 Watt
- Speakers
- 2 x speaker - 5 Watt
Network & Internet Multimedia
- Supported Consumer Electronics Control (CEC)
- Simplink
- Connector Type
- 2 x HDMI , USB , Composite video / component video input , LAN , Digital audio output (optical)
- Batteries
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 110.8 cm x 8.2 cm x 65.7 cm x 10.6 kg , Panel with stand - 110.8 cm x 21.8 cm x 70.7 cm x 10.9 kg
- Width (Shipping)
- 119.7 cm
- Depth (Shipping)
- 16.2 cm
- Height (Shipping)
- 77.5 cm
- Weight (Shipping)
- 14.1 kg
