LG 49" SM8600 4K Ultra HD Nanocell Smart TV
Quicklinx: FR64WS00 Mfr#: 49SM8600PLA
  • DVB-S
  • DVB-T
NanoCell TV, The Best LED TV from LG
NanoCell TV is LG's most advanced LED TV that delivers superior picture quality with enhanced RGB colour purity thanks to LG's NanoCell technology.
  • NanoCell technology – for accurate colour
  • New 2nd Gen a7 Processor with AI
  • Control your TV and your home with your voice
  • Dolby Vision & Atmos Cinema Experience at home
  • 4K Cinema HDR Delivering the filmmaker’s vision
  • Minimalistic design Blends in to any space
Refined Colour Purity
Nano Color delivers a stunning visual experience with NanoCell technology that enhances the purity of colour using about 1nm nanoparticles.
Reveal Pure Colours with NanoCell Technology
Pure RGB colours are the key to realistic picture quality. NanoCell Technology applies nanoparticles that purify colours by filtering out dull colours and enhancing the purity of the RGB spectrum.
Wide Viewing Angle. Colours Stay Accurate.
Unlike conventional TVs that may distort colours when a picture is viewed from the side, LG NanoCell TV preserves colour so that no matter where you sit, you will get a rich, colourful picture.
4K Cinema HDR Delivers The Filmmaker's Vision
LG's 4K Cinema HDR trues to the filmmaker's vision with the support of most HDR formats. Be immerse in cinematic images with major HDR formats including Advanced HDR by Technicolor and HDR10 Pro.
  • Reveal pure colors with NanoCell technology
    Pure RGB colors are the key to realistic picture quality. NanoCell technology applies nanoparticles that purify colors by filtering out dull colors and enhancing the purity of the RGB spectrum.
  • Precise color expression at a wide viewing angle
    Wherever you sit, NanoCell TV maintains accurate color, even from the sides, and allows everyone to enjoy the realistic picture.
  • Wide viewing angle, colors stay accurate
    Unlike conventional TVs that may distort colors when a picture is viewed from the side, LG NanoCell TV preserves color so that no matter where you sit, you will get a rich, colorful picture.
  • 4K Cinema HDR
  • Dolby Vision & Atmos - cinema experience at home
    Dolby transforms your home into an entertainment powerhouse with cinematic HDR imaging and sound.
  • Simple, harmonious design
    LG NanoCell TV's Nano Bezel and sleek design will fit beautifully into any living room.
  • Flawless 4K HDR gaming
    LG NanoCell TV is perfect for gamers. With ultra-low input lag meaning the difference between victory and defeat, and cinematic images thanks to 4K and HDR, get the most immersive experience with fast action and eye-popping color.
LG 49SM8600PLA SM86 Series - 49" LED-backlit LCD TV - 4K
LED-backlit LCD TV - Smart TV
Diagonal Class
49"
Platform
webOS, LG ThinQ AI
Resolution
3840 x 2160
Display Format
4K Super UHD (2160p)
HDR Format
Dolby Vision, HLG10
HDR Technology
HDR Effect, 4K Cinema HDR, Technicolor Advanced HDR, HDR10 Pro
Frame Rate & Enhancement Technology
3300 Picture Mastering Index
Video Interface
HDMI
HDMI Ports Qty
4 ports
Wi-Fi, LAN, Bluetooth
IPS
LCD Backlight Technology
Edge-lit LED, Nano Cell Display local dimming
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
Internet Streaming Services
HbbTV, Voice Search, Live Plus, Home Dashboard
Picture Enhancements
4K Upscaling, Auto Calibration, True Colour Accuracy, Billion Rich Colours, Nano Cell Color, Object Depth Enhancer, Luminance Optimizer, Quad Step Noise Reduction, Frequency Based Sharpness Enhancer, Advanced Color Enhancer, HDR Dynamic Tone Mapping, Deep Learning AI Picture, AI Brightness
Speaker System
2 speakers
Sound Effects
ULTRA Surround
Platform
SmartThinQ, Google Home ready
Intelligent Assistant
Google Assistant (not available for some languages and countries)
USB
3 ports
LG MR19 remote control
Voltage
Energy Class
Class A
Power Consumption (On mode)
87 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
121 kWh
109.6 cm x 6.36 cm x 64 cm
14 kg
Energy Class
Class A
87 W
121 kWh
Diagonal Class
49"
Series
SM86 Series
Platform
webOS, LG ThinQ AI
HDR Capable
HDR Format
Dolby Vision, HLG10
HDR Technology
Video Processor
?7 Gen 2 Intelligent
TV Tuner Presence
Extended PVR
Sensors
Illuminance green sensor
Video Interface
HDMI
HDMI Ports Qty
4 ports
Modes
Hotel mode, Gallery Mode
Dimensions
Without stand
109.6 cm
6.36 cm
64 cm
14 kg
Display
LCD Display Technology
IPS
Resolution
3840 x 2160
Display Format
Image Aspect Ratio
16:9
Edge-lit LED, Nano Cell Display - local dimming
Display Menu Language
Multilingual
Audio Description (AD), time-shift, Multi View, Wireless TV On, Ultra Luminance, 10-bit support, Virtual Reality (360 VR) function, 2K High Frame Rate (HFR), a7 Gen 2 Intelligent Processor, Instant Game Response, Quad-Core processor
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
VESA Compatibility
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
HEVC, VP9
Supported Audio Formats
MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS, MP2, AC4
USB Port
USB Ports Qty
3
Remote Control
Remote control
Remote Control Model
LG MR19
Battery Form Factor
AA type
Battery Included Qty
2
Magic remote
Audio System
Digital Audio Format
Dolby Digital output, DTS digital output, DTS-HD digital output, Dolby Atmos
Surround Mode
Sound Effects
ULTRA Surround
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in DTS decoder, Down-firing Speaker, Bluetooth Audio Streaming, text to speech function, Audio Return Channel (ARC), Dolby Surround Sound, apt-X technology, Simultaneous Audio, Clear Voice III technology, LG Sound Sync, Intelligent Voice Recognition, One Touch Sound Tuning, speech-to-text function, AI Sound, Auto Notification, WiSA speakers
Speakers
2 x speaker - 10 Watt
Network & Internet Multimedia
Functionality
WEB browsing, Internet video playback
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11ac
Bluetooth Version
Bluetooth 5.0
Connect & Share
Screen Share
Supported Consumer Electronics Control (CEC)
Simplink
Application Store
LG Content Store
Connector Type
2 x HDMI - rear , 2 x HDMI - side , 2 x USB - rear , USB - side , Headphone output , LAN - rear , Digital audio output (optical) - rear , Audio line-out / headphones - rear
Internet of Things (IoT)
Platform
Power supply
Input Voltage
0.5 Watt
Energy saving mode
Dimensions & Weight Details
Panel without stand - 109.6 cm x 6.36 cm x 64 cm x 14 kg , Panel with stand - 109.6 cm x 26.31 cm x 71 cm x 15.5 kg
Width (Shipping)
119.2 cm
Depth (Shipping)
16.2 cm
Height (Shipping)
81 cm
Weight (Shipping)
18.4 kg
