NanoCell TV, The Best LED TV from LG
NanoCell TV is LG's most advanced LED TV that delivers superior picture quality with enhanced RGB colour purity thanks to LG's NanoCell technology.
- NanoCell technology – for accurate colour
- New 2nd Gen a7 Processor with AI
- Control your TV and your home with your voice
- Dolby Vision & Atmos Cinema Experience at home
- 4K Cinema HDR Delivering the filmmaker’s vision
- Minimalistic design Blends in to any space
Refined Colour Purity
Nano Color delivers a stunning visual experience with NanoCell technology that enhances the purity of colour using about 1nm nanoparticles.
Reveal Pure Colours with NanoCell Technology
Pure RGB colours are the key to realistic picture quality. NanoCell Technology applies nanoparticles that purify colours by filtering out dull colours and enhancing the purity of the RGB spectrum.
Wide Viewing Angle. Colours Stay Accurate.
Unlike conventional TVs that may distort colours when a picture is viewed from the side, LG NanoCell TV preserves colour so that no matter where you sit, you will get a rich, colourful picture.
4K Cinema HDR Delivers The Filmmaker's Vision
LG's 4K Cinema HDR trues to the filmmaker's vision with the support of most HDR formats. Be immerse in cinematic images with major HDR formats including Advanced HDR by Technicolor and HDR10 Pro.
Reveal pure colors with NanoCell technology
Pure RGB colors are the key to realistic picture quality. NanoCell technology applies nanoparticles that purify colors by filtering out dull colors and enhancing the purity of the RGB spectrum. -
Precise color expression at a wide viewing angle
Wherever you sit, NanoCell TV maintains accurate color, even from the sides, and allows everyone to enjoy the realistic picture. -
Wide viewing angle, colors stay accurate
Unlike conventional TVs that may distort colors when a picture is viewed from the side, LG NanoCell TV preserves color so that no matter where you sit, you will get a rich, colorful picture. -
4K Cinema HDR
LG's 4K Cinema HDR trues to the filmmaker's vision with the support of most HDR formats. Be immerse in cinematic images with major HDR formats including Advanced HDR by Technicolor and HDR10 Pro. -
Dolby Vision & Atmos - cinema experience at home
Dolby transforms your home into an entertainment powerhouse with cinematic HDR imaging and sound. -
Simple, harmonious design
LG NanoCell TV's Nano Bezel and sleek design will fit beautifully into any living room. -
Flawless 4K HDR gaming
LG NanoCell TV is perfect for gamers. With ultra-low input lag meaning the difference between victory and defeat, and cinematic images thanks to 4K and HDR, get the most immersive experience with fast action and eye-popping color.
- LG 49SM8600PLA SM86 Series - 49" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 49"
- Platform
- webOS, LG ThinQ AI
- Resolution
- 3840 x 2160
- Display Format
- 4K Super UHD (2160p)
- HDR Format
- Dolby Vision, HLG10
- HDR Technology
- HDR Effect, 4K Cinema HDR, Technicolor Advanced HDR, HDR10 Pro
- Frame Rate & Enhancement Technology
- 3300 Picture Mastering Index
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- Technology
- IPS
- LCD Backlight Technology
- Edge-lit LED, Nano Cell Display local dimming
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- HbbTV, Voice Search, Live Plus, Home Dashboard
- Picture Enhancements
- 4K Upscaling, Auto Calibration, True Colour Accuracy, Billion Rich Colours, Nano Cell Color, Object Depth Enhancer, Luminance Optimizer, Quad Step Noise Reduction, Frequency Based Sharpness Enhancer, Advanced Color Enhancer, HDR Dynamic Tone Mapping, Deep Learning AI Picture, AI Brightness
- Speaker System
- 2 speakers
- Sound Effects
- ULTRA Surround
- Platform
- SmartThinQ, Google Home ready
- Intelligent Assistant
- Google Assistant (not available for some languages and countries)
- USB
- 3 ports
- Included Accessories
- LG MR19 remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- Power Consumption (On mode)
- 87 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 121 kWh
- Dimensions (WxDxH) - without stand
- 109.6 cm x 6.36 cm x 64 cm
- 14 kg
- Product Type
- Energy Class
- Class A
- 87 W
- 121 kWh
- Diagonal Class
- 49"
- Series
- SM86 Series
- Platform
- HDR Capable
- HDR Format
- HDR Technology
- Video Processor
- ?7 Gen 2 Intelligent
- TV Tuner Presence
- Extended PVR
- Sensors
- Illuminance green sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 4 ports
- Modes
- Hotel mode, Gallery Mode
- Dimensions
- Without stand
- 109.6 cm
- 6.36 cm
- 64 cm
- 14 kg
Display
- LCD Display Technology
- IPS
- Resolution
- 3840 x 2160
- Display Format
- 16:9
- Edge-lit LED, Nano Cell Display - local dimming
- Display Menu Language
- Multilingual
- Audio Description (AD), time-shift, Multi View, Wireless TV On, Ultra Luminance, 10-bit support, Virtual Reality (360 VR) function, 2K High Frame Rate (HFR), a7 Gen 2 Intelligent Processor, Instant Game Response, Quad-Core processor
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Teletext
- Teletext Memory
- 2000 pages
- Electronic Programme Guide
- Digital EPG
Media Player
- Supported Video Formats
- HEVC, VP9
- Supported Audio Formats
- MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, DTS, MP2, AC4
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- LG MR19
- Battery Form Factor
- AA type
- Battery Included Qty
- 2
- Magic remote
Audio System
- Digital Audio Format
- Dolby Digital output, DTS digital output, DTS-HD digital output, Dolby Atmos
- Surround Mode
- Sound Effects
- ULTRA Surround
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in DTS decoder, Down-firing Speaker, Bluetooth Audio Streaming, text to speech function, Audio Return Channel (ARC), Dolby Surround Sound, apt-X technology, Simultaneous Audio, Clear Voice III technology, LG Sound Sync, Intelligent Voice Recognition, One Touch Sound Tuning, speech-to-text function, AI Sound, Auto Notification, WiSA speakers
- Speakers
- 2 x speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Bluetooth Version
- Bluetooth 5.0
- Connect & Share
- Screen Share
- Supported Consumer Electronics Control (CEC)
- Simplink
- Application Store
- LG Content Store
- Connector Type
- 2 x HDMI - rear , 2 x HDMI - side , 2 x USB - rear , USB - side , Headphone output , LAN - rear , Digital audio output (optical) - rear , Audio line-out / headphones - rear
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Energy saving mode
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 109.6 cm x 6.36 cm x 64 cm x 14 kg , Panel with stand - 109.6 cm x 26.31 cm x 71 cm x 15.5 kg
- Width (Shipping)
- 119.2 cm
- Depth (Shipping)
- 16.2 cm
- Height (Shipping)
- 81 cm
- Weight (Shipping)
- 18.4 kg
