LG 49" Curved UltraWide DualQHD (32:9) IPS Monitor
Quicklinx: HV8HWS00 Mfr#: 49WQ95C-W.AEK
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
£1,104.38 ex VAT
£1,325.25 inc VAT
It is an UltraWide 32:9 dual QHD (5120 x 1440) monitor with a doubled 27-inch 16:9 QHD pixel space in one screen. With 70% more pixels compared to 32:9 FHD resolution (3840 x 1080), you can go beyond multitasking with a multi-format multiplex.
  • Save time with less window switching
    With 49WQ95C that displays much more image sources and windows at once, save time for visual work.
  • Manage the whole timeline
    Check thumbnails of the source files and upload the files to the timeline with no switching windows.
  • Do work simultaneously
    You can check the storyboard with the entire timeline on a single screen when working on music.
  • Expand your workspace
    Stack monitors and get a screen size of four 27-inch monitors as well as wider and neat desk space.
  • Control multiple devices with a single monitor
    Dual controller allows you to work with multiple devices through a single monitor, keyboard and mouse. Just simply drag and drop the files from various devices into your single monitor.
  • Outstanding color accuracy and wide viewing angle
    LG Nano IPS display supports a wide color spectrum, 98% of DCI-P3 color gamut, and offers outstanding color and brightness with the support of VESA DisplayHDR 400.
  • Live Color Low Blue Light
    LG's Live Color Low Blue Light with TÜV Rheinland Eyesafe Display Certification helps to protect your eyes against blue light by combining RGB hardware and software adjustments while maintaining vivid color quality.
  • Auto brightness with ambient light sensor
    The sensor reacts to light, making the screen brighter in bright areas and darker in the dark. It provides a comfortable working environment.
  • Easy connectivity
    USB Type-C port allows from display and data transferring to connected device charging, enabling support for your laptop all at the same time over a single cable.
  • Power Delivery
    With USB-C power delivery technology, you can power up a monitor, while charging the connected laptop simultaneously.
  • Immersive gaming experience
    Just dive into the gaming with the outstanding graphic background provided by 144Hz of refresh rate, NVDIA G-sync Compatible and AMD Free Sync as well as the gaming aid features.
  • Speedy screen, smooth gameplay
    A fast speed of 144 Hz allows gamers to see the next frame quickly and makes image to appear smoothly. The gamers can response rapidly to opponents and aim at target easily.
  • Immersive sound system
    This streamlined display features a slim bezel on three sides and no distractions from the dazzlingly precise, lifelike image while two 10W Stereo Speakers with MaxxAudio completes your immersive experience.
  • Be sleek and more ergonomic
    Enhanced flexibility offers expanded ergonomic adjustment of height, tilt and swivel, setting your monitor to fit into your optimal position.
LG UltraWide 49WQ95C-W - LED monitor - curved - 49" - HDR
LED-backlit LCD monitor - 49"
Energy Class
Class F
Curved Screen
Adaptive-Sync Technology
AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible
USB Hub, KVM Switch, USB PD 90 Watt
Panel Type
Nano IPS
Aspect Ratio
32:9
Native Resolution
UltraWide Dual QHD 5120 x 1440 at 144 Hz
Pixel Pitch
0.234 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10 / DisplayHDR 400
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
98% DCI-P3 (CIE 1976)
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Voltage
AC 100-240 V (50/60 Hz)
121.51 cm x 28.1 cm x 58.58 cm
14.7 kg
TUV Rheinland
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
49"
Curved Screen
Yes (3800R)
Built-in Devices
USB Hub, KVM Switch
USB Power Delivery
90 Watt
Panel Type
Nano IPS
Aspect Ratio
32:9
Native Resolution
Pixel Pitch
0.234 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
HDR Certification
DisplayHDR 400
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDR Effect, Factory Calibration, Auto Brightness Control, Flicker Safe, Reader Mode, Super Resolution+, Color Weakness Mode, Variable refresh rate (VRR), Black Stabilizer, DAS Mode (Dynamic Action Sync), Crosshair Display, user defined key, 2PBP, Smart Energy Saving technology, picture in picture, Live Colour Low Blue Light, Rich Bass, ambient light sensor
121.51 cm x 28.1 cm x 58.58 cm - with stand
14.7 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
2 x HDMI , DisplayPort , USB-C (power up to 90W) , Headphones (mini-jack) , USB 2.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
30
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
TUV Rheinland
Input Voltage
45 kWh/1000h
Power Consumption HDR (On mode)
109 kWh/1000h
Power Consumption (Typical)
103 Watt
Power Consumption (Max)
113 Watt
Power Consumption Sleep
0.4 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
LG On-Screen Control, Dual Controller Software, MaxxAudio
Dimensions & Weight Details
With stand - width: 121.51 cm - depth: 28.1 cm - height: 58.58 cm - weight: 14.7 kg , Without stand - width: 121.51 cm - depth: 11.42 cm - height: 36.57 cm - weight: 12.6 kg
Shipping Width
133 cm
Shipping Depth
29.8 cm
Shipping Height
49 cm
Shipping Weight
19.6 kg
Diagonal Size: 49in
Response Time: 5ms
Interfaces: USB-C
Interfaces: HDMI
Brand: LG
Price Range Ex VAT: £1000 - £1500
