LG 39.7" 40WP95CP-W 5K2K Curved UltraWide Nano IPS Display
Quicklinx: HV8FWS00 Mfr#: 40WP95CP-W.AEK
11 In Stock
£1,082.50 ex VAT
£1,299.00 inc VAT
The 5K2K UltraWide (5120 x 2160) resolution is great for your creative work as it can display various programs such as video editing, virtual instruments and effects at once.
  • A new level of color performance
    With Nano IPS display, it supports a wide color spectrum, 98% of DCI-P3 color gamut, and offers vibrant color reproduction with the support of HDR10.
  • Thunderbolt 4 and multi ports
    Thunderbolt 4 lets you enjoy up to an 5K2K display, data transferring to connected device charging (up to 96 W) over a single cable with stability, scalability, and security. Also, This LG UltraWide monitor offers USB 3.0, HDMI, and DisplayPort compatible with various devices.
  • The productive workstation
    Thunderbolt and DisplayPort support Daisy Chain setup. So you can establish a productive workstation by connecting two monitors and a laptop.
  • Increase viewing comfort while maintaining color quality
    LG's Live Color Low Blue Light with TÜV Rheinland Eyesafe display certification helps to protect your eyes against blue light by combining RGB hardware and software adjustments while maintaining vivid color quality.
  • Auto brightness with ambient light sensor
    The sensor reacts to light, making the screen brighter in bright areas and darker in the dark. It provides a comfortable working environment.
  • Comfortable workspace
    The One Click Stand makes it easy to install without any other equipment, and you can customize the monitor to your optimal position with height, tilt, and swivel adjustment.
  • AMD FreeSync
    Gamers can experience seamless, fluid movement in hi-resolution and fast-paced games.
  • Dynamic Action Sync
    Reduce input lag with Dynamic Action Sync so it helps gamers catch critical moments in real-time.
  • Black Stabilizer
    Gamers to avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes.
  • Rich Bass speaker
    10 W stereo speakers with Rich Bass completes your immersive experience.
LG UltraWide 40WP95CP-W - LED monitor - curved - 40" - HDR
LED-backlit LCD monitor - 40"
Energy Class
Class F
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Daisy Chaining
USB PD 96 Watt
Panel Type
Nano IPS
Aspect Ratio
21:9
Native Resolution
5K2K UltraWide 5120 x 2160 at 72 Hz
Pixel Pitch
0.1815 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
98% DCI-P3 (CIE 1976)
Input Connectors
2xHDMI, DisplayPort, USB-C, Thunderbolt 4
Display Position Adjustments
Height, swivel, tilt
Voltage
AC 100-240 V
Dimensions (WxDxH) - with stand (highest position)
94.72 cm x 28.3 cm x 61.47 cm
12.3 kg
TUV Eyesafe Display Certification, TUV Rheinland Low Blue Light (Hardware Solution)
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
40"
Viewable Size
39.7"
Curved Screen
AMD FreeSync
Daisy Chaining
USB Power Delivery
96 Watt
Panel Type
Nano IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.1815 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Ambient light sensor, Auto Brightness Control, Low Blue Light Mode, Flicker Safe, Reader Mode, Wide Colour Gamut, Smart Energy Saving technology, Color Calibrated, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Hardware Calibration Ready, One Click Stand, Super Resolution+, Rich Bass, HDR Effect, auto input switch, Live Colour Low Blue Light, 2PBP
94.72 cm x 28.3 cm x 61.47 cm - with stand (highest position)
12.3 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
2 x HDMI , DisplayPort , USB-C (DisplayPort Alt Mode, data, power up to 96W) , Thunderbolt 4 (power up to 96W) , 2 x USB 3.0 downstream , Headphones (mini-jack)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
30
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x Thunderbolt 4 / USB-C cable
Security Slot Type
Kensington security slot
Input Voltage
AC 100-240 V
40 kWh/1000h
Power Consumption HDR (On mode)
72 kWh/1000h
Power Consumption (Typical)
60 Watt
Power Consumption (Max)
70 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dual Controller Software, True Color Pro, LG On-Screen Control
Dimensions & Weight Details
With stand (highest position) - width: 94.72 cm - depth: 28.3 cm - height: 61.47 cm - weight: 12.3 kg , With stand (lowest position) - width: 94.72 cm - depth: 28.3 cm - height: 50.47 cm - weight: 12.3 kg , Without stand - width: 94.72 cm - depth: 11.48 cm - height: 41.92 cm - weight: 10.2 kg
Shipping Width
105 cm
Shipping Depth
25 cm
Shipping Height
51 cm
Shipping Weight
16.6 kg
Brand: LG
Price Range Ex VAT: £1000 - £1500
